Valve Cover 1927
Posted: Wed Nov 03, 2021 6:30 pm
by Greg sarky k
What is the correct color for valve covers in 1927?
Greg
Re: Valve Cover 1927
Posted: Wed Nov 03, 2021 7:21 pm
by George House
...engine color
Posted: Wed Nov 03, 2021 9:05 pm
by Humblej
In general, for 26-27, cast parts are moleskin, stamped parts are black.
Posted: Sat Nov 06, 2021 6:46 pm
by J1MGOLDEN
I have always wondered about that or what color moleskin is, as I have never seen a green mole.
Posted: Sat Nov 06, 2021 6:55 pm
by MichaelPawelek
Posted: Sat Nov 06, 2021 10:36 pm
by ModelTWoods
Does the MTFCA Encyclopedia give this information? Painting the stamped steel parts a different color than the cast parts' color, would certainly set them off, but I can't believe Henry Ford would put that expense into a Model T engine. It took him 18 years, just to change the head bolts and some other engine hardware from painted to nickle plated.
Posted: Sun Nov 07, 2021 7:28 am
by Joe Bell
There was so many sheet metal parts made and it came down the line for 24-5 they got throwed on a 26-7 to use them up so it was not taking more time he was using up old parts. I have seen on original cars a 13 front fender on a 14 and the other side being a 14 fender, it does not take much to notice a body line in a fender but it happens!
Posted: Sun Nov 07, 2021 8:40 am
ModelTWoods wrote: ↑Sat Nov 06, 2021 10:36 pm
Here is info from MTFCA Encyclopedia, that valve cover was painted engine color, black if black engine, and green if green engine (Moleskin). This is for late Improved cars with the Vaporizer carb set up.
- 27 brochure engine cropped close .jpg (23.95 KiB) Viewed 2109 times
Posted: Thu Nov 11, 2021 6:43 am
by Humblej
Found this picture of the 15 millionth model T. This one looks like Model A engine green and frankly this engine color is questionable since the body has been repainted the wrong color two different times, the engine could have been repainted at some time too.
