Adjusting toe in
Posted: Wed Nov 03, 2021 7:45 pm
by John L
Ok ; got my axle straight and ready to put it back together. What is the best way to adjust toe in ,toe out?
Re: Adjusting toe in
Posted: Wed Nov 03, 2021 7:48 pm
by TWrenn
Sending you an email.
Posted: Wed Nov 03, 2021 8:57 pm
by Steve Jelf
Posted: Wed Nov 03, 2021 10:49 pm
by Charlie B in N.J.
You really want to get it right? Sure you do and the best garage way I’ve found is to get 4 pieces of tin or galvanized about 4” square. Make 2 sandwiches of grease between 2 pieces and put one under each front tire so they slide easy. Nothing beats the accuracy you’ll get if those tires can move.
Posted: Thu Nov 04, 2021 3:44 am
by ABoer
I do it a little differed
Toon
Posted: Thu Nov 04, 2021 5:30 am
by Mark Osterman
Like the system … but white carpet in a garage housing a model T. Boy are you brave.
Posted: Thu Nov 04, 2021 8:46 am
by RGould1910
Clever, Anthonie!
Posted: Thu Nov 04, 2021 9:28 am
by speedytinc
ABoer wrote: ↑Thu Nov 04, 2021 3:44 am
I believe your method or minor variations are the most accurate way to go.
Wheel center height front & back, mark tires.
I mark the tires front & roll back 1/2 revolution.
Posted: Thu Nov 04, 2021 9:48 am
by Quickm007
Toon, I like your way. What measurement we need to have?
Posted: Thu Nov 04, 2021 10:05 am
by Ed Baudoux
I like to use magazines or catalogs for slip pads. Most model T Ford front ends are loose enough to use 1/4" of toe in.
Posted: Thu Nov 04, 2021 10:45 am
by TWrenn
Pretty much how I do it and explained to him, but I use a clamped pair of yardsticks to guage the distance front and back, and have had excellent results. Much easier. Helps to have a lift also!
On my '13 I have zero toe in..really rolls nice. Other two cars are at the spec 1/4".
Posted: Thu Nov 04, 2021 11:10 am
by Norman Kling
I do it the way Tim does it. I adjust the drag link to the point where it is zero or just out in front from zero. Then I lengthen one rotation and tighten the clamp. It might not be right on, but is as close as you can get it without bending the spindle arm.
Posted: Thu Nov 04, 2021 12:38 pm
by Art M
I agree with Anthony's method. If front linkage is in good condition, I recommend 1/32 to 1/4 inch toe in. Keep in mind that one turn on the tie rod changes the toe in by about .22 inches.
Art Mirtes
