Engine Rebuild Question
Topic author - Posts: 121
- First Name: Jason
- Last Name: Given
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
We tore down the kid's 25 engine to rebuild the tranny. That's done, before putting it all back together, we decided we would check over the rest of the engine.
Right now it's a short block, only has the cam, pistons/crank, and valve train.
It is really difficult to turn over. I loosened the bolts holding the caps. I added a 1 ft cheater bar to the crank shaft, and it is still hard to turn.
Before pulling the crank shaft, how difficult should it be to turn over at this point?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: Engine Rebuild Question
From the looks of it, it has been sitting for awhile? Might be more drag coming from the cylinders.
Hope this Helps,
Hope this Helps,
- Last Name: Hanlon
- MTFCA Number: 50191
I agree with Hank.
Take the rods loose and push the pistons up (if you can) and it'll probably turn easier then.
If the pistons are tight, I would take them out and clean/check cylinders and rings.
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Is bad as some one has cut the seat in two of the exhaust valve your chance of having a crack from the valve into the cylinder has increased.
- MTFCA Number: 14972
- MTFCI Number: 15411
Agree on the exhaust seat - not good & you should really replace the original 2 pc. valves - this is what they like to do - "come from together " !
- First Name: Jason
- Last Name: Given
So how can you tell they are two piece valves, from that image?
By the 2 holes in the top for the Ford (& others) valve grinding tool.
- MTFCA Number: 28924
The original 2 piece valves will usually have the 2 holes in the top of the valve that were used when grinding the valves with the older hand valve grinders.
In the pic of the broken valve shown the valve stem has the darkened end. The end is darker because it was up inside the back of the head of the valve.
- First Name: Keith
- Last Name: Gumbinger
- MTFCA Number: 4661
- MTFCI Number: 6866
I absolutely agree with what the others said about replacing the 2 piece valves. Further, you should clean all the carbon from the top of the pistons & the block. By installing modern valves, cutting the seats and lapping the new valves in, you'll have a much better running and longer lasting engine.
Keith
Keith
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
Could just be the photo...but that #3 piston and cylinder wall look suspect.
1924 Touring
- Last Name: van Ekeren
Don't assume just because of the 2 holes on top make them 2 piece valves, replacement one piece steel ones also had the tool holes right up into the 70/80's?. One would need to look at the other side of the valve head to know for sure.
- First Name: Jason
- Last Name: Given
I'm guessing I have 4 two piece valves. They were in positions, 1, 2, 3 & 8.
Jason, your guess is right.
- MTFCA Number: 24868
Yup. Two piece valves. And, by the looks of most of them, they weren't really doing much anymore, except just going up & down. The engine photo also makes it appear as if the seats have been cut waaaaaay deep. Time for inserts I think, and new valves too of course.
- First Name: Harold
- Last Name: Schwendeman
I'm not too sure on this, but I think it might be possible to install oversize valves in that block without new seats. Seems like something like the slightly larger Fordson tractor valves or maybe a more modern automotive valve with modern valve spring keepers might be available. If that's possible, there is an advantage to carefully cutting new seats in the block for oversize valves,.....and that is that heat is radiated from exhaust valves directly into the iron block more efficiently than into a new valve seat inserts and THEN into the block. That of course means that the exhaust valves would run a bit cooler (and that's a good thing) than with newly inserted valve seats. Maybe somebody that know more about it than me might "chime in" here. Anyway, I'd sure check it out,....FWIW,....harold
