Help with steam engine id?
Posted: Fri Nov 05, 2021 4:13 pm
by Angmar
Wondering if any of you have good infromation on this engine and or where I can go to get more information on it.
thanks in advance.
Meant to put this in the off topic, not sure how to move it now.
Re: Help with steam engine id?
Posted: Fri Nov 05, 2021 5:10 pm
by kevinf
Try Smokestack, and list it in the steam forum. You might get lucky, just be aware there were a lot of jobbers building engines, some with very limited production. Good luck, Kevin
Posted: Fri Nov 05, 2021 5:14 pm
by kevinf
Sorry you will need to go to www.oldengine.com, and then go to the smokestack forum.
Posted: Sat Nov 06, 2021 1:22 pm
by Angmar
Thank you.
Posted: Sat Nov 06, 2021 2:41 pm
Closest I could find. for "Vertical Steam Engine". There are many similar in shape but none with the same dual fly wheels. These were used in small locomotives, boats etc
Posted: Sat Nov 06, 2021 9:39 pm
by RichardG
most likely what you have is a Kerwood, made for sears and many other outlets, the only way to find for sure is the casting numbers IF there are any,, i have owned several over the years, i have a picture taken of me 50 years ago at a show with one i saved, it ran a sausage grinder in a butcher shop,in the day not every one had electric wiring and motors to do the work but they had boilers, i will find the photo to show, that type engine was refered to as a bottle engine, depending on boiler pressure 4-6 hp,
Posted: Sat Nov 06, 2021 11:13 pm
by Herb Iffrig
I have one that is similar in construction that is marked Climax.
Posted: Sun Nov 07, 2021 9:40 pm
by Angmar
a few more photos. Thanks for the help guys.
Posted: Mon Nov 08, 2021 1:18 am
it would help to know what this says...
??canton Pump C0. A20?? Canton Ohio
Posted: Mon Nov 08, 2021 6:37 pm
by kevinf
That last photo is of a duplex pump
Steam cylinders on one side and the pump cylinders on the other. Used as a boiler feed pump.
