I Almost Threw This Useless Screwdriver Away….
Posted: Wed Nov 10, 2021 7:49 pm
by MichaelPawelek
Last year. It came with a set of regular screwdrivers. Today when I installed the Bendix cover with my arthritic fingers it sure came in handy though I don’t know what it is called….😊
Re: I Almost Threw This Useless Screwdriver Away….
Posted: Wed Nov 10, 2021 7:51 pm
It's a Godsend when you need one.
Posted: Wed Nov 10, 2021 8:44 pm
If you don't have that, you can do the same thing by putting a screw on the screwdriver with a piece of tape.
Posted: Wed Nov 10, 2021 8:49 pm
by Dan Hatch
In shop I started in years ago, we called them Monday Morning Screwdrivers.
Posted: Thu Nov 11, 2021 7:56 am
by Cap
I prefer this type.. Gets into smaller spaces, and will screw hold upon extraction..
This is the one I use on the cover..
https://www.mcmaster.com/screw-holding- ... e~slotted/
Cap
Posted: Thu Nov 11, 2021 7:57 am
by perry kete
I have used screwdrivers like that for years. I picked mine up at the electrical supply house and use it to hold the ground screw or other screws deep inside an outlet or light switch box. They work great when working overhead applying covers on junction boxes etc.
Posted: Thu Nov 11, 2021 8:01 am
by TWrenn
I USED to have one. :lol: Sadly, I lost it. :roll: I need to get another one. they're super handy.
Posted: Thu Nov 11, 2021 10:47 am
I got one from McMaster Carr.
Posted: Thu Nov 11, 2021 11:15 am
by George Mills
Like Tim, I use to have one. It was the two blade slide sleeve type with a really long shaft. Worked great. Somebody wanted it more than I did.
I now have one of the spring clip kind and they work well...just a bit tight for stubby fingers...
Posted: Thu Nov 11, 2021 11:35 am
by John Codman
Cap
I do too, but we have both.
Posted: Wed Nov 24, 2021 2:24 pm
by Mikey1968
You can also use a dab of EZ Turn fuel proof grease as it's pretty sticky stuff. I've started nuts that I could only get my finger tip on it by putting a dab on my finger tip and sticking the nut to it.
Posted: Wed Nov 24, 2021 4:27 pm
by perry kete
The problem with using sticky grease is that as soon as I put it on my finger my nose becomes itchy and I always use the finger with the grease on to scratch it! :shock:
Posted: Wed Nov 24, 2021 5:02 pm
I jam the head of the screw in a short bit of rubber fuel line, then use an ordinary electrician's screwdriver poked down the fuel line. Works a treat.
Posted: Wed Nov 24, 2021 9:03 pm
by Mark Osterman
The old trick was slipping a short piece of thin rubber tubing over the end of the screw driver to hold the screw.
Posted: Wed Nov 24, 2021 9:17 pm
by Dan B
Posted: Fri Nov 26, 2021 10:40 am
by Mikey1968
Itchy nose to grease issue! :lol: Been there! What's worse is when you get a dob of silver anti-seize on your fingers and don't realize it. You get silver all over the place and yourself!
