Gaskets
- MTFCA Number: 4838
- MTFCI Number: 115
Re: Gaskets
Gasket sets from the Model T vendors, listed on the home page here, are just fine. Can't really tell variations to these. Most kits sell for $35 w/o head gasket. That adds another $18 -$29 depending on the type of head gasket you want. So about $60 for vendor non-branded sets that always perform for me.
On-line you can buy name brand "FelPro" gasket kit for the Model T, but it is an obsolete part so comes with the associated 'obsolete' part price. Typical offerings on that set are $140 - $160, but Summit site still shows the kit as complete, but the photo shows no timing cover gasket, so don't know if it is included or not. But at that high price, the Model T vendors that supply our needs, have a lower purchase price and besides, they support our hobby too.
Topic author - Posts: 3
- First Name: Charles
- Last Name: Legg
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordoor
- Board Member Since: 2004
Re: Gaskets
I bought gaskets for the rear axle. None of them fit. They were all to small. I’m thinking about using a stainless steel shim to replace the gasket and then seal it with permatex. The gasket for the rearend halves was 1/2 “ too short.
- MTFCA Number: 14383
Re: Gaskets
Thats not a gasket, its a shim. Axle housings didnt have gaskets. Get your clearences & assemble with ultra black silicone.
Otherwise, in general paper gaskets dry out & shrink. Soak them in water to get them back to size.
- MTFCI Number: 115
Re: Gaskets
Paper gaskets that are very thin and narrow like those shrink when dry. Just spray with water and they become flexible again and full size.
Remember too much gasket at the pumpkin halves can separate your desired fit established for the thrust washers.
- MTFCA Number: 52564
Re: Gaskets
I have been leaving the rear end center section gasket out unless need just a smige more clearance, I use Permatex #2. While there may be some variations between the suppliers parts suppliers, they pretty much are all the same gaskets. Yes, plant fiber (paper) gaskets do shrink over time as they dry out if the gaskets have been on the shelf for a while, as do the cork composite.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Gaskets
Some gaskets are best bought ready-made (front cover, generator mount, pan). Others are easily made at home with gasket paper from the local parts store (water inlet & outlet, carb-to-manifold, Bendix cover, et al.)
Re: Gaskets
If you need a gasket/shim to set up the two halves, you could just remove the same thickness from the right hand side bronze thrust washer. If you trim the left side washer, it may upset your pinion/crown wheel mesh. Then assemble with the sealant of your choosing.
Re: Gaskets
Ford added a housing gasket in 1919, so in fact we are leaving them out and just using sealer. The gaskets between the pinion housing and center were not used, and are shims to adjust the depth of the pinion gear.
1920 Dodge touring
1920 Dodge touring
Re: Gaskets
Maybe anecdotal, but I have parted out MANY rear ends.Mark Gregush wrote: ↑Wed Dec 01, 2021 2:07 amFord added a housing gasket in 1919, so in fact we are leaving them out and just using sealer. The gaskets between the pinion housing and center were not used, and are shims to adjust the depth of the pinion gear.
Never seen any signs of a gasket between the housings. FWIW.
Something to research further,
Re: Gaskets
Mark Gregush wrote: ↑Wed Dec 01, 2021 2:07 amFord added a housing gasket in 1919, so we are leaving them out and just using sealer. The gaskets between the pinion housing and center were not used, and are shims to adjust the depth of the pinion gear.
1920 Dodge touring
1920 Dodge touring
Re: Gaskets
I "think" I have, but in truth, really was not paying enough attention to log it into my memory.
1920 Dodge touring
1920 Dodge touring
- MTFCI Number: 115
Re: Gaskets
Paragraph 617 notes to place that axle case gasket
- First Name: Michael
- Last Name: Peternell
Re: Gaskets
Sad to say but one of the people producing paper gaskets is not with us anymore.
- First Name: Ray
- Last Name: Maciej
- * REQUIRED* Type and Year of Model Ts owned: 1915 touring, 1925 roadster
- MTFCA Number: 28154
Re: Gaskets
Yes, we miss you already Andy!
- First Name: Mike
- Last Name: Virnig
- * REQUIRED* Type and Year of Model Ts owned: 1925 Touring
- MTFCA Number: 49729
Re: Gaskets
Amen to that Ray.
