piston clearance
mel.k53
First Name: MELVIN
Last Name: king
* REQUIRED* Type and Year of Model Ts owned: 1915@1923 roadsters
piston clearance
Post by mel.k53 » Sat Dec 04, 2021 1:46 pm
I just bought a set of pistons and it says 2 to 3 tho clearance, it seems tight to me ,what do you think for new pistons? MEL
Last Name: Gregush
MTFCA Number: 52564
Re: piston clearance
Post by Mark Gregush » Sat Dec 04, 2021 2:24 pm
Mine .004 to .005, but I usually go with the .005. That puts it in the .001 per inch of diameter.
1920 Dodge touring
Sean Butler
First Name: Sean
Last Name: Butler
MTFCA Number: 31557
Post by Sean Butler » Sat Dec 04, 2021 2:39 pm
Mark's got it.
Sean Butler
Huntington Beach, CA
Post by Norman Kling » Sat Dec 04, 2021 3:45 pm
What Mark says if the pistons are aluminum. If steel they can be a bit tighter.
J and M Machine
Last Name: Gulbankian
Post by J and M Machine » Sat Dec 04, 2021 6:10 pm
It depends on condition of the block: We thermal clean the engines so they get the heat transfer. We set our cylinders to their recommended 3 thousandths clearance and have never had and issue.
