Gas Line Details For Headlights
Topic author - Posts: 3284
- MTFCA Number: 121
- MTFCI Number: 16310
I finally wrapped up my 1913 headlight hook up today. I have some photos, but need more. I'll take them tomorrow and post the pictures then. I can say one thing for sure. The kits that Ron Gocek made were 100% incorrect, except for some of the tubing which was one foot too short!
- MTFCA Number: 121
Re: Gas Line Details For Headlights
Here are the dimensions. Headlights 9", Frame to radiator 8", Carbide tank to frame line 28".
- MTFCA Number: 121
Here are more photos:
- Attachments
- Gas Light #11.JPG (60.2 KiB) Viewed 6389 times
- Gas Light #10.JPG (33 KiB) Viewed 6389 times
- Gas Light #9.JPG (31.1 KiB) Viewed 6389 times
- Gas Light #8.JPG (51.21 KiB) Viewed 6389 times
- Gas Light #6.JPG (51.59 KiB) Viewed 6389 times
- MTFCA Number: 121
More Photos: I'm not good a taking photos, or posting them either. If you have further questions, email me directly!
- Attachments
- Gas Light #15.JPG (50.84 KiB) Viewed 6388 times
- Gas Light #14.JPG (45.75 KiB) Viewed 6388 times
- Gas Light #13.JPG (64.95 KiB) Viewed 6388 times
- Gas Light #12.JPG (49.71 KiB) Viewed 6388 times
- MTFCA Number: 121
Ron Goceks kit didn't supply enough tubing for this job. A 13-14 takes 4 feet, with 3" left over maybe. I found 1/2" red rubber tubing from McMaster Carr. They delivered it in one day. Haven't had a chance to use it yet. I made the entire system from the Ford prints. I also have an original frame line, which is exactly like the Ford print. There is a hole in the frame just forward of the controller shaft for the support bracket.
- First Name: Rich
- Last Name: Bingham
Well that certainly clears up a lot of questions about the plumbing and its routing ~! Thanks much, Larry !
"Get a horse !"
- MTFCA Number: 121
I'm sorry some of the photos are dark. Maybe the flash didn't go off. I'm hopeful that you guys can figure this out!
- First Name: Kenneth
- Last Name: Parker
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1925
Thank you for posting the photos. The setup looks great and the tee and sleeve have that "thick wall" look to them.
The photo below is on the assembly line and the little brass hose clamps sure look small. They installed the gas headlight hoses in the radiators before they came down to the line. I used clamps but I don't think they are really necessary if the hose is snug.
On your rear gas hose to the generator, I ran it over the brake rod like you have it. It was sitting on the rod so I tied the hose off to the running board support with a plastic tie. The hose was from Langs and I was afraid the rod would rub a hole in it.
Since you are going to use carbide, I am anxious to see your report. I started out with tank gas and have never used my generator.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Larry-
Nice work!
Nice work!
- First Name: Jeff
- Last Name: Perkins
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout 1926 Touring
- MTFCA Number: 10642
- MTFCI Number: 17799
Thank You Larry. As I research and gather information to help restore my recent purchase 1913 I find this invaluable.
1913 Model T Runabout,
1926 Model T Touring,
1948 Chrysler New Yorker,
1991 Mazda Miata
1991 Mazda Miata
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Ken...what is that a picture of? Thanks
- Last Name: Wrenn
Never mind Ken!! God I'm blind!!! Now, after CAREFULLY reading your post, I see that's
a line of radiators looking at them from the top of the tank. Sheesh! Better get to the eye doctor!! LOL
- Last Name: Parker
Tim,
My mistake,
I should have put the whole photo up and an arrow to what I was talking about!
My mistake,
- MTFCA Number: 121
I can't help this! Notice, the horns are all mounted correctly!
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Thank you sharing this, I`m close to istall my Gas line on my 1911.
Mario
Mario
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
- First Name: Keith
Mario
I hope you are only using this information for encouragement. The 1911 gas lines are completely different.
Keith
Keith
- First Name: Mario
Exactly Keith after 8 year restored my 1911 we could lost the focus ...
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
