Champion X: Loose top?
ArthurB
First Name: Arthur
Last Name: Babitz
Post by ArthurB » Thu Mar 28, 2019 10:13 pm
I have some "vintage" Champion X (crimped brass top, long insulator) plugs and noticed on one the brass top rotates, but the electrode at the far end does not rotate with it. How is the electrode attached to the brass top and screw? Is this a problem? Is this fixable?
Also, the copper crush washer is missing. Is there a good substitute? I have a Champion 25 with good crush washer in it. Can I borrow that one? Thanks!
MTFCA Number: 16175
MTFCI Number: 14758
Re: Champion X: Loose top?
Post by Steve Jelf » Thu Mar 28, 2019 10:24 pm
I've never destroyed one to find out, but I believe the electrode is soldered to the cap. If it's become detached I think it's time for a replacement. Yes, you can probably use the same washer. Info on replacement washers is here:
http://dauntlessgeezer.com/DG95.html
ArthurB
First Name: Arthur
Last Name: Babitz
Post by ArthurB » Fri Mar 29, 2019 12:48 pm
Hmm, if the electrode is soldered to the cap I might be able to reflow the solder with my heat gun. I'll try it this weekend.
Steve Hughes
Last Name: Hughes
MTFCA Number: 216
MTFCI Number: 23070
Post by Steve Hughes » Fri Mar 29, 2019 1:31 pm
I’v Had a couple that the threaded part has twisted off. The electrode is’nt soldered. Just touches. Or may even have a slight air gap, but it doesn’t hinder the spark at the end of the plug.
