Should There be a Cutter Key Here?
Posted: Mon Dec 06, 2021 8:41 pm
by BLB27
Photos of my 1927 coupe front axle are attached. Should there be a cutter key on this nut?
Re: Should There be a Cutter Key Here?
Posted: Mon Dec 06, 2021 8:44 pm
by Bill Robinson
4 sure! a widow maker if there's not one!
Posted: Mon Dec 06, 2021 8:48 pm
Yes !!!!!!
Posted: Mon Dec 06, 2021 8:59 pm
by Chris Haynes
Cotter Pin.
Posted: Mon Dec 06, 2021 9:07 pm
Not only a cotter pin, but be sure the nut is the proper special nut with a convex bottom to mate to the concave surface of the wishbone.
Posted: Mon Dec 06, 2021 10:38 pm
Hope those nuts are loose also the perches, so you can line them up when spring is installed? That one perch looks 90 degrees out of alignment.
Posted: Tue Dec 07, 2021 1:28 am
I have not seen a nut like that one! Whatever nut is used, it does need a split pin.
Posted: Tue Dec 07, 2021 9:10 am
Yes it needs a cotter pin! You may need to use a pick to dig out the paint to find the hole for the pin to go in.
Posted: Tue Dec 07, 2021 11:36 am
You can leave the cotter pin out if you want to have a wreck.
Posted: Tue Dec 07, 2021 11:56 am
Mark Gregush wrote: ↑Mon Dec 06, 2021 10:38 pm
That's the one with the cotter pin issue. BUT are the perches on the correct ends - boss to the back.
Posted: Tue Dec 07, 2021 12:18 pm
by ThreePedalTapDancer
http://www.mtfca.com/discus/messages/70 ... 1513701371
- 88F36F59-7474-4A11-92E0-4B7405938B99.jpeg (54.49 KiB) Viewed 3234 times
Posted: Wed Dec 08, 2021 7:43 pm
by BLB27
I was almost sure a cotter pin was needed, but thought I would ask. I am glad I did because of all the good cotter pin information that was posted. Thanks to you all.
Posted: Wed Dec 08, 2021 8:56 pm
BLB27 wrote: ↑Wed Dec 08, 2021 7:43 pm
Castellated nuts are designed to use cotter pins & not lock washers. However, not every nut on a Model T is a castellated one. So make sure the nuts are good before you try and insert your pin.
Posted: Thu Dec 09, 2021 3:46 pm
Thanks for posting this cotter pin use chart.
I find even this "trivia" level of info very interesting & helpful to my T knowledge base.
Thats appreciation to any & all posting this sort of enlightening information.
