26 hogs head
Posted: Tue Dec 28, 2021 5:11 pm
by RichJ
Has any one modified an regular block to mate to a 26 hogs head using the mounting ears?
Re: 26 hogs head
Posted: Tue Dec 28, 2021 5:15 pm
I haven't, and I'd speculate that the earlier blocks would not have enough iron in that area to do it.
Re: 26 hogs head
Posted: Tue Dec 28, 2021 7:22 pm
by mike catlin
Took the holes in the 26 hogshead and threaded a plug-in.Then taped the plug to accept a 5/16 bolt so I could still use the two arms that connect to the frame rails.
Re: 26 hogs head
Posted: Tue Jan 04, 2022 12:35 am
by Ken Buhler
That is not stopping the pan twist which causes broken crankshafts.
Re: 26 hogs head
Posted: Tue Jan 04, 2022 11:12 am
by George House
Ken is right. Just get those 2 accessory L brackets that fit under the crankcase with 4 bolt holes each that stabilizes the tranny cover, pan and block. I’m at the Dr. office now but someone will list the correct nomenclature.
Re: 26 hogs head
Posted: Tue Jan 04, 2022 11:57 am
George House wrote: ↑Tue Jan 04, 2022 11:12 am
Oil Pan Supports
L's
https://www.modeltford.com/item/3118-19.aspx
Belly
https://www.modeltford.com/item/3114SPT.aspx
