Engine hood not sitting well
Posted: Wed Dec 29, 2021 4:00 am
Hello.
I kindly want to ask what I can do, the engine hood is not following well the shape of the radiator.
When I got my Lizzy, the steel rod on top was rusted in. This I could solve, I turned the rod left and right until I could pull it out. Then I sanded it,applied a bit of grease as rust protection, and re-inserted it. It still goes a bit hard, but it does not stick any more.
The paintwork at upper joint is also flaking off a bit besides the loops because there was a lot of filler used and simply painted over. But it was too high, co it was partially scraped off by the other half of the engine hood. This will need some more work, I am afraid.
Also the engine hood is not following the shape of radiator very well. Where it is bent approx 45degrees, it does not sit well, it is not bent sufficiently. It is reaching out 1/4" over radiator shape.
Looking to the inner side, I see a stripe of leather. It is hard as concrete, was painted over by the former owner with car paint. I have no pictures yet, but this weekend I can take some. At the moment I can only show a very blurry one, but I am very sure that this problem is well known.
On above picture you can see where the engine hood stands off. To fix this, I will have to bend the sheet metal of all four parts a bit more. This makes me nervous. I can use a piece of 1 1/2" or 2" pipe place the sheets on it, and then bend, but it can (and probably will) happen that the paint will flake off (together with this "high quality" filler underneath). Also, there is a holding clamp riveted to the upper parts of the hood inside, holding the super-hard and soaked in black paint leather stripe, so the engine hood will not be laying well on the pipe at all.
I will also need to remove the old leather. It is so hard that it is galling the radiator's brass. It needs to be replaced by something new (either leather or a stripe of black rubber. But how do I get new leather under the holding clamp? I am scared that prying it up is the wrong way, it will not return t its current position. I also cannot hammer it down, this can damage the outer paint, too. Pulling the old leather seems to be possible.
Suggestions?
I know the hard way: Pull the old leather, pry up the holding clamp a little bit to make new leather slide in easily, bend the hood into correct shape (hereby possibly causing cracks in paint), then completely repaint it, and finally glue in new leather (instead of hammering down the holding clamps).
But if possible, I would like to do it less destructively.
Suggestions?
