12v Battery
Posted: Sun Mar 31, 2019 5:36 pm
by TspokeMan
Any thoughts for a new battery for my '25 T Roadster pu? Size, amp, etc?
Re: 12v Battery
Posted: Sun Mar 31, 2019 5:41 pm
Are you converting, or is it already done?
Re: 12v Battery
Posted: Sun Mar 31, 2019 7:34 pm
by Tim Rogers
At your local Tractor Supply...
- 6v.jpg (8.6 KiB) Viewed 5982 times
Re: 12v Battery
Posted: Sun Mar 31, 2019 9:15 pm
A good group 1 6 volt is all you need.
Re: 12v Battery
Posted: Mon Apr 01, 2019 10:08 am
by TspokeMan
It has been converted to 12v
Re: 12v Battery
Posted: Mon Apr 01, 2019 10:12 am
by TspokeMan
Tim Rogers wrote: ↑Sun Mar 31, 2019 7:34 pm
Thanks for the pic Tim. Can you give me the battery info? The pic is not clear enough to read.
Re: 12v Battery
Posted: Mon Apr 01, 2019 10:30 am
The photo IS a group 1 - 6 volt.
Re: 12v Battery
Posted: Mon Apr 01, 2019 10:40 am
For more dough they have EverStart with a three year warranty.
3101 East Kansas Avenue
Starter Motor 6 or 12 volt.
Posted: Mon Apr 01, 2019 1:31 pm
by Novice
Is Your starter motor 12 volts. or a original 6 volt starter running on 12 volts ? My 26 was converted to 12 volts when I got it. but the starter is still 6 volts which I am not comfortable with.The 12 volt battery in My 26 is a Napa Power # 6535. I have considered replacing the 12 volt battery with two 6 volt Optima's which will fit in the same space ? and provide 6 volt for starting and use 12 volts for charging and running distributor, lights. and accessories.
Walmart Value Power.
Posted: Mon Apr 01, 2019 1:52 pm
by Novice
The Value power line of batteries seem to work well. I have bought two and use one on a 88 S-10 parked in the barn. over three years on the value power battery and counting. using a 6.95 HF. Cen-Tech Automatic float charger # 42292. which I think is the reason for the long battery life. if I take the float charger off for a few weeks the battery goes down.
Re: 12v Battery
Posted: Mon Apr 01, 2019 10:58 pm
If your battery is going down in weeks, it is either the alternator pulling it down (if you have an alternator) or oil-soaked wiring providing a high resistance path to ground.
I had the same situation and found that replacing the old wiring (that was also found to be pinched against the frame) solved the problem and in a warm climate, the battery could go 5 months and still start the car. Prior to that , I'd be lucky to get the car to start after sitting for a week (and this is with the same 6V battery). On this same car, the coolant was eating up my aluminum Moto-meter, and the coolant was showing (I don't recall how much) millivolts of voltage when checked with DVM. After replacing wiring, the moto-meter stopped corroding as well, and DVM measured "0". There was definitely leakage due to wiring.
