Which way should the blade cut?
Posted: Sun Mar 31, 2019 5:38 pm
Should the teeth cut when pushing, when pulling, or does it matter?
Re: Which way should the blade cut?
Posted: Sun Mar 31, 2019 5:43 pm
by Les Schubert
Normally when pulling
Posted: Sun Mar 31, 2019 5:44 pm
by Ruxstel24
I would think when pushing, most hand saws do.
Posted: Sun Mar 31, 2019 5:51 pm
by George Andreasen
Ironic............I just junked a perfectly good Keller because I couldn't even GIVE it away......
Rotate the motor pulley by hand while carefully watching the blade. It should RAISE perceptibly on the return stroke, not cutting stroke, which saves the teeth.
Or, if you seem to be going through blades way too fast, turn them around.
Posted: Sun Mar 31, 2019 6:33 pm
Les is correct...cut on the pull, and George is correct in that there should be a cam which lifts the blade up a little for the return (outward) stroke
Posted: Sun Mar 31, 2019 6:52 pm
by Sparknwire
Teeth toward the back of the saw
Posted: Sun Mar 31, 2019 6:57 pm
by Roz
It should turn ccw as you are looking at the blade side of the saw, and cut on the pulling stroke. Those are good saws. When the blade wears out, you can make several nice knife blades from it.
Posted: Sun Mar 31, 2019 8:54 pm
by John E. Guitar
The old blades also make great gasket scrapers.
Posted: Sun Mar 31, 2019 9:02 pm
by Ruxstel24
John E. Guitar wrote: ↑Sun Mar 31, 2019 8:54 pm
A little drift...
One of the best gasket scrapers I had was a kitchen knife ground square. Got in narrow places great.
I don't think the ex even missed it
Posted: Sun Mar 31, 2019 11:08 pm
by kelly mt
My old Marvel #2 saw lifts the blade on the forward stroke.
Posted: Tue Apr 02, 2019 6:55 am
My transmission drum balancing rig has two such blades with the back of the blade ground almost to a knife edge, on which the axle in the mandrels runs.
Posted: Tue Apr 02, 2019 12:55 pm
by Barth_Tool_Co
My Marvel 9A cuts on the pull, teeth on the blade face towards the back of the saw. The manual states this is correct for that saw.
These are neat tools, fun to watch!
by Barth_Tool_Co
kelly mt wrote: ↑Sun Mar 31, 2019 11:08 pm
So does my Marvel 9A.
Posted: Tue Apr 02, 2019 2:14 pm
The Keller is less sophisticated than the Marvel. The blade rests on the work in both directions.
Posted: Tue Apr 02, 2019 2:55 pm
by Barth_Tool_Co
Steve Jelf wrote: ↑Tue Apr 02, 2019 2:14 pm
Out of curiosity Steve, how many teeth per inch on the blade you're running?...
Posted: Tue Apr 02, 2019 4:08 pm
by Walter Higgins
The cutting load should be applied to the stationary jaw.
Posted: Tue Apr 02, 2019 11:10 pm
by kelly mt
Where are you guys finding blades? I found some good quality fine blades but no course blades. I forget the TPI.
Posted: Tue Apr 02, 2019 11:35 pm
The blades I'm using are 10 TPI Vanguard, made in England.
