1926 Ford Model T
4banger1988
First Name: Patrick
Last Name: Ortlauf
* REQUIRED* Type and Year of Model Ts owned: 1926 Ford Model T Two Door Sedan
1926 Ford Model T
Post by 4banger1988 » Mon Apr 01, 2019 7:57 am
Hi
I am Patrick from Germany
have a Model T from 1926
Have him now running, I'm already gone
Just wanted to introduce myself
My English is not that good.
Here are a few pictures if it works with the upload
greetz patrick
4banger1988
First Name: Patrick
Last Name: Ortlauf
Re: 1926 Ford Model T
Post by 4banger1988 » Mon Apr 01, 2019 7:59 am
4banger1988
First Name: Patrick
Last Name: Ortlauf
Post by 4banger1988 » Mon Apr 01, 2019 8:01 am
4banger1988
First Name: Patrick
Last Name: Ortlauf
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Mon Apr 01, 2019 8:07 am
Looks like a solid body. You will have alot of fun with it. Thanks for showing us.
Welcome to the forum!
Keep us posted on your progress and we like lots of photos.
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Post by John.Zibell » Mon Apr 01, 2019 9:18 am
With that vaporizer carburetor it may be a 1927. Take a look at the engine and frame numbers. The frame number will be on top of the right hand frame just in front of the passenger seat. Post that number and someone here can tell you the date it was made. Also top wood kits are available from the US vendors as well as the top material kit.
1926 Tudor
Novice
First Name: Jim
Last Name: Davis
MTFCA Number: 49832
MTFCI Number: 24686
WELCOME PATRICK. Nice 26
Post by Novice » Mon Apr 01, 2019 10:25 am
Patrick. Welcome to the Forum and the wonderful world of Model Ts. My Grandfather was a Burkhardt of German decent. had a model T shop in the 20s and 30s. across the road from The church in the photo with My yellow 26 touring. Established by German settlers in 1965 and the Church in the photo built by German Church members in late 1800s after the first one burned.They had services in German until the mid 1950s.
WELCOME WELCOME WELCOME
Novice
First Name: Jim
Last Name: Davis
MTFCA Number: 49832
MTFCI Number: 24686
TYPO 1865 not 1965
Post by Novice » Mon Apr 01, 2019 10:29 am
Welcome again. Patrick
4banger1988
First Name: Patrick
Last Name: Ortlauf
Post by 4banger1988 » Mon Apr 01, 2019 2:59 pm
Thanks for the friendly reception
but the 1926 is the same as the 1927 Model T or did the 1926 not have this carburetor?
I have a problem with the first gear
at the beginning he was still only now no adhesion is there anymore.
Only second gear and reverse functions
Are there friction pads in there and how can I fix it? Does the complete engine have to get out of gear?
or is that easier?
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Mon Apr 01, 2019 4:15 pm
Welcome to the insanity, Patrick.
You need to check out your low band. Adjustment is done simply from outside the hogshead/transmission cover.
I would probably take of the inspection cover and look at the drums and check the other bands also.
http://www.mtfca.com/discus/messages/80257/89737.html
John.Zibell
Last Name: Zibell
MTFCA Number: 30265
MTFCI Number: 24046
Post by John.Zibell » Mon Apr 01, 2019 5:03 pm
or is that easier?
The 1926 model year used the NH carburetor and has a hole through the block for the throttle linkage. In 1927, the vaporizer was used and the linkage goes over the top with no hole in the block between cylinder 2 and 3. You English is fine. If what you want to say gets complicated for you there is always google translate. https://translate.google.com/ aber es ist auch nicht perfekt
I just noticed the radiator mounting system isn't quite right. If it is a solid mount, you may encounter radiator damage. see https://www.snydersantiqueauto.com/Prod ... t/radiator
1926 Tudor
Last Name: House
MTFCA Number: 115
Post by George House » Mon Apr 01, 2019 7:25 pm
Das ist eine schoen T Model. Sie will haf lotsa speiss mit it.... see there ! Your English is better than meine deutch.... wilkommen !!!!
I don’t know why I turned out this way. My parents were decent people 🤪
Novice
First Name: Jim
Last Name: Davis
MTFCA Number: 49832
MTFCI Number: 24686
Basic operation.
Post by Novice » Mon Apr 01, 2019 8:34 pm
Patrick. You can down load books and information on the transmission with drawings and details on how the transmission and all the other parts of the car fit together and work. The transmission has three bands similar to the bands / clutches used in modern automatic transmission's. and the friction / band tightness can be adjusted inside the transmission / Hogshead with a adjustment tool. Low band. Reverse band and Brake pedal band. not to be confused with the emergency / parking brake leaver on the floor that activates the two rear drum brakes and puts the car transmission in neutral. The transmission goes into high gear when You take Your foot off the left pedal which releases the clutch if brake leaver is all the way forward. I hope I am not over simplifying, I am still a "Novice" with much to learn.
Good Luck Jim
4banger1988
First Name: Patrick
Last Name: Ortlauf
Post by 4banger1988 » Tue Apr 02, 2019 2:27 pm
Okay thank you very much
Yes, the cooler is not original
the bracket is homemade
what should happen there?
Well
I would like to have all the books for my model
maybe the ones the mechanics used to have
with good pictures
Is there any to buy or download here?
Engine, transmission, electrical system, axle, suspension everything just
greetz patrick
JWalters
First Name: Jason
Last Name: Walters
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by JWalters » Tue Apr 02, 2019 3:50 pm
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Tue Apr 02, 2019 4:04 pm
Patrick, your English is just fine. Ich spreche nur ein bischen Deutsch, aber ich kann Sie helfen. Send me a ticket and I will fly right over.
If you can fine Mike Benders video's on you tube, you will learn a lot. That will be easier for you while you wait for the books.
dave
Jim_PTC_GA
Last Name: Fisher
* REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
MTFCA Number: 31822
Post by Jim_PTC_GA » Tue Apr 02, 2019 4:56 pm
Welcome. Beautiful car you got there. Looks like it will be fun. My wife is over there near Duesseldorf this week for work. She tells me there are a few T guys working with her so there are others in country you can hook up with.
Just give me time to Rust and I'll be good as new. :) Wabi-Sabi
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Wed Apr 03, 2019 7:38 pm
Is it kind of "hilly" where you are? I have friends/family in Taunusstein, Hesse a bit north, and from what I've heard
and seen on photos, seems like a lot of winding, hilly roads, not great for model T driving. Just wondering!
Markus
First Name: Markus
Last Name: Huether
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
Post by Markus » Fri Apr 05, 2019 5:46 am
Hi Patrick,
very nice car. You bought it right now?
When you need some help, i can assist you. I live near KTown (Kaiserslautern) in Germany.
Markus
