Lighted Propeller Radiator Ornament
Bud_T
First Name: Ed
Last Name: Daniel
* REQUIRED* Type and Year of Model Ts owned: none
MTFCA Number: 0
MTFCI Number: 0
Post by Bud_T » Thu Jan 13, 2022 2:40 pm
Hi, For the pictured ornament, can someone tell me how the ornament ITSELF is assembled, particularly the propeller. I already know how it attaches to the radiator cap. I am not interested in the wiring. If someone has a picture of how the shaft is attached that supports the propeller, I would like to look at that. Also, if someone has the dimensions of this shaft, I would appreciate knowing that as well. My ornament has a shaft that appears to be press fit in the aluminum legs, but there is nothing to hold the propeller on, unless the ball bearing is press fit to the shaft. Thank you!
