ignition problem
Posted: Mon Apr 01, 2019 9:31 am
my 24 touring has 4 mid 50s kw coils. i took it out for a spin and had a sudden skip. i found that it ran better on the 6v battery and got home.
switched back to mag. and found that no 4 was not firing switched the coils around and the problem moved so it is a coil problem. i did the
light bulb volt meter magneto test and have good voltage. the coil that is not good has a bigger blue spark at the coil itself than the others.
do i need a new capacitor
why does it work on battery
any advice would be great. philip
