Johnson Tinning compound
Posted: Sat Jan 15, 2022 6:13 pm
Has anyone used the Johnson tinning compounds for doing the caps? I have not priced them yet.
http://www.johnsonmfg.com/temp/tinning.htm
Thinking this one might work;
JOHNSON'S TIN-EZY POWDER with PURE TIN
This Full Strength Tinning Without Lead
Johnson's Tin-Ezy with Pure Tin tins quickly, yet contains no lead. Like Johnson's regular Tin-Ezy, it is made in a low-humidity environment to keep it dry and free-flowing for increased storage life. This special chloride flux formulation is blended with only Grade-A Pure Tin powder. Johnson Tin-Ezy with Pure Tin is compatible with all solders however, it is particularly useful for tinning new metal, using Johnson's 497 Lead-Free Solder. Melting temperature is 450° F. Residues are water soluble and should be removed after soldering.
ITEM SINGLE CASE NO. IN CASE SHIP WT.
1 Lb. Jar 20-62 20-63 12 14#
3 Lb. Jar 20-64 60-65 6 21#
12 Lb. Pail 20-66 20-67 4 52#
Lot will depend on price.
