Painting Carb
Posted: Sun Jan 16, 2022 12:03 am
by BLB27
I am rebuilding a late NH carb. I plan to apply a prime coat and a black finish coat. What is the best way to apply, brush or rattle can? What is a good paint to use? I plan on using Rust-Oleum.
Re: Painting Carb
Posted: Sun Jan 16, 2022 12:15 am
by jiminbartow
Just use your best judgement… sometimes just wingin’ it is the best way to go…
Re: Painting Carb
Posted: Sun Jan 16, 2022 1:40 am
by TRDxB2
BLB27 wrote: ↑Sun Jan 16, 2022 12:03 am
In case you don't have rebuild instructions
https://modeltfordfix.com/rebuilding-th ... el-t-ford/
I'd use Rust-Oleum Automotive Engine Paint is good enough for any heat concerns. Plug all holes see instructions on rebuild.
Re: Painting Carb
Posted: Sun Jan 16, 2022 1:56 am
by George N Lake Ozark
I used engine paint, primer is already in it.
Re: Painting Carb
Posted: Sun Jan 16, 2022 3:50 am
by Allan
I don't paint them at all. That way it can't be attacked by fuel.
Re: Painting Carb
Posted: Sun Jan 16, 2022 8:31 am
by John Illinois
Model airplane fuel proof dope works well. I use it on model A gas gauge numbers which are submerged in gas.
https://sigmfg.com/collections/covering ... dope-black
John
Re: Painting Carb
Posted: Sun Jan 16, 2022 11:15 am
by Steve Jelf
I've always used rattle can Rustoleum satin black. I dislike glossy paint on chassis parts. The Rustoleum doesn't need a primer.
Since this pictire was taken I've painted the filter. Same paint.
Re: Painting Carb
Posted: Sun Jan 16, 2022 12:06 pm
by sweet23
I use black lacquer in a spay can. Gas will not attack it. no primer.
Re: Painting Carb
Posted: Mon Jan 17, 2022 11:31 am
by Quickm007
I found this, but still hard to find a correct solution
https://spraygadgets.com/gas-resistant- ... Tank_Paint
Re: Painting Carb
Posted: Mon Jan 17, 2022 11:45 am
by Dropacent
I had a half dozen NOS carbs several years ago, and the bodies were probably black parkerized originally. Not sure what they called it way back then, but it was a rustproofing treatment that left the bodies with a dull blackish/gray finish. NEVER painted. This can be easily replicated if you check on line, lots of easy methods. This all if you want original look. Otherwise, paint away
Re: Painting Carb
Posted: Mon Jan 17, 2022 11:59 am
by TRDxB2
Rust-Oleum Engine Enamel Spray Paint is a high temperature engine paint protects your engine from the harmful effect of heat, oil, gas, grease, rust, salt, solvents, and humidity. It is made for manufactured for the cars’, bikes’ as well as other automotive engines. Rust Oleum Engine Enamel Spray resists high-heat up to 260°C and gives a smooth finish to your engine surface. This forms a long-lasting coating that keeps out chipping and peeling offering an enduring finish. Interestingly, a single spray can is well-enough to paint 10-12 sq.ft of an area.
Available at automotive stores everywhere -
Re: Painting Carb
Posted: Tue Jan 18, 2022 3:14 pm
by Quickm007
Hi, I used personnaly an electric Paint Sprayer which is cheap and work really well. I used for Engine Enamel paint or personal use at home.
The one I used cost me only $67 in Canadian dollars on Amazon. It may cost ONLY $46 US$ and you can choose the paint you like.
Re: Painting Carb
Posted: Tue Jan 18, 2022 10:32 pm
by jpcouture
I used TopFlite fuel resistant model airplane paint from a local hobby shop. It is the only thing I have found that has survived the toxic Minnesota gas formula. My Model A carb has lasted 8 years, still solid. The Rustoleum on the engine pan underneath turned to goop long ago.
