I need to find floor cover pictured
- Last Name: Patrick
- MTFCA Number: 50126
Re: I need to find floor cover pictured
I can’t tell from the picture, the size and shape of the projections. Check McMaster Carr (www.McMaster.com). Search “rubber mats” then choose projections. There might be a mat design close to what you need. Jim Patrick
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
- MTFCA Number: 17802
Check with Wittmer Coach in New Holland, PA. I found black pyramid rubber matting there. It is sold by the yard. I then painted it with flexible white paing.
Check with Wittmer Coach in New Holland, PA. I found black pyramid rubber matting there. It is sold by the yard. I then painted it with flexible white paint.
- First Name: David
- Last Name: Schwab
Restoration Supply Co. has white vinyl 1/4” pyramid 48” wide, $29.00 per foot.
- MTFCA Number: 1219
Page 33 of their online catalog. They have Vinyl, Rubber and aluminum.
- First Name: Erik
- Last Name: Johnson
The late Ken Jones restored a 1911 roadster and it has pyramid aluminum floor covering over the rear floorboards.
If I recall correctly, the original pyramid aluminum was in rough shape but he was able to find a suitable replacement which is probably the same pyramid aluminum that is posted in the catalog above.
- Last Name: Gresh
- MTFCI Number: 15762
How much do you need?
If you can’t find any,
I probably have a roll.
Topic author - Posts: 444
- First Name: Dean
- Last Name: Brevit
Thanks everyone, I think I found some at a lower price (could be junk) 36" wide $5.00 per linear foot, I ordered 8' . If it's not correct I will take you up on your offer Larry. Again, Thank All.
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
That is looking really nice Dean. Will you be painting or staining the floorboards before you put the mats down? What do you plan to use to hold the mats down so they dont curl up in the corners? Hope you can bring your car to Nebraska some day for the Speedster Union.
- First Name: Dean
- Last Name: Brevit
Thanks again, I will paint the floor with black paint, I have brushed on some West System epoxy already, will sand and paint soon. The hard part is dry fitting everything then taking it all apart for paint, I'm going to use 3M spray adhesive for vinyl to hold down covering, if it lifts at the corners I'll put a small tack in.DHort wrote: ↑Thu Feb 10, 2022 12:35 pmThat is looking really nice Dean. Will you be painting or staining the floorboards before you put the mats down? What do you plan to use to hold the mats down so they don't curl up in the corners? Hope you can bring your car to Nebraska some day for the Speedster Union.
