1915: What's correct here?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Jan 17, 2022 9:20 pm
The Colorado fastener list only deals with chassis parts. What belongs in this hole?
MTFCA Number: 14972
MTFCI Number: 15411
Re: 1915: What's correct here?
Post by RajoRacer » Mon Jan 17, 2022 9:37 pm
Nothing - shouldn't be there.
TMiller6
First Name: Thomas
Last Name: Miller
* REQUIRED* Type and Year of Model Ts owned: 16, 24, 26 Touring - 26 Roadster and Fordor
MTFCA Number: 14069
Board Member Since: 2006
Post by TMiller6 » Mon Jan 17, 2022 9:54 pm
My ‘16 has that hole as do other cars I’ve seen. I have only seen black round head slotted machine screws used there.
Tom Miller
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Mon Jan 17, 2022 10:11 pm
Steve, I think by now you probably have a feel for what my 1915 body is, and what it isn't. I have no way of knowing if these round head slotted screws have always been in these holes, but all the same doesn't look like they've ever been removed either. I'll let you decide.
Please note the bolts in the driver cowl wood below are not original. That partocular section was rotten and missing one bolt on my car and Dad fitted a new 3" or so piece and found and old looking nut and bolt from one of his T parts cans. Then painted the new wood lightly with flat black to make it look old. Ha.
Andy
Offending rotten section
Best picture of the passenger side screw
Close up of driver side screw with repaired wood framework
modeltbarn
First Name: Gary
Last Name: London
MTFCA Number: 16592
Post by modeltbarn » Mon Jan 17, 2022 10:26 pm
My 15’s had that hole, and I don’t recall anything going there. When my dad needed a starter in his Runabout we placed a button switch to control a solenoid there. Not original, but it was very low profile.
Sheri
First Name: Sheri
Last Name: Cameron
* REQUIRED* Type and Year of Model Ts owned: 1909, 1911, 1915
Post by Sheri » Mon Jan 17, 2022 10:33 pm
All 1915 cars have that hole. All cars had a round head slotted bolt with a nut on the back side.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Mon Jan 17, 2022 11:01 pm
Mine has a carriage bolt.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Jan 18, 2022 12:52 am
But it's a round hole. I expect the hole for a carriage bolt would be square.
MTFCA Number: 51486
Post by TXGOAT2 » Tue Jan 18, 2022 9:41 am
Is there another piece of metal behind what is visible? If so, I'd put a round head slotted screw in it to secure the joint.
MWalker
Last Name: Walker
MTFCA Number: 314
Post by MWalker » Tue Jan 18, 2022 10:14 am
I believe Sheri (whom I suspect is actually Mark using Sheri's account) has the correct answer.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Jan 18, 2022 10:44 am
I stand corrected - never had a "modern" open car !
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Tue Jan 18, 2022 1:49 pm
Two options: Use a slot head screw or get a carriage bolt, file off the corners a bit. Either way just so it will match.
MTFCA Number: 1219
Post by Rich Eagle » Tue Jan 18, 2022 5:57 pm
Some more pictures to ponder.
