1915: What's correct here?
Posted: Mon Jan 17, 2022 9:20 pm
The Colorado fastener list only deals with chassis parts. What belongs in this hole?
Re: 1915: What's correct here?
Posted: Mon Jan 17, 2022 9:37 pm
Nothing - shouldn't be there.
Posted: Mon Jan 17, 2022 9:54 pm
by TMiller6
My ‘16 has that hole as do other cars I’ve seen. I have only seen black round head slotted machine screws used there.
Posted: Mon Jan 17, 2022 10:11 pm
by Retro54
Steve, I think by now you probably have a feel for what my 1915 body is, and what it isn't. I have no way of knowing if these round head slotted screws have always been in these holes, but all the same doesn't look like they've ever been removed either. I'll let you decide.
Please note the bolts in the driver cowl wood below are not original. That partocular section was rotten and missing one bolt on my car and Dad fitted a new 3" or so piece and found and old looking nut and bolt from one of his T parts cans. Then painted the new wood lightly with flat black to make it look old. Ha.
Andy
Posted: Mon Jan 17, 2022 10:26 pm
by modeltbarn
My 15’s had that hole, and I don’t recall anything going there. When my dad needed a starter in his Runabout we placed a button switch to control a solenoid there. Not original, but it was very low profile.
Posted: Mon Jan 17, 2022 10:33 pm
by Sheri
All 1915 cars have that hole. All cars had a round head slotted bolt with a nut on the back side.
Posted: Mon Jan 17, 2022 11:01 pm
by KWTownsend
Mine has a carriage bolt.
Posted: Tue Jan 18, 2022 12:52 am
But it's a round hole. I expect the hole for a carriage bolt would be square.
Posted: Tue Jan 18, 2022 9:41 am
Is there another piece of metal behind what is visible? If so, I'd put a round head slotted screw in it to secure the joint.
Posted: Tue Jan 18, 2022 10:14 am
by MWalker
I believe Sheri (whom I suspect is actually Mark using Sheri's account) has the correct answer.
Posted: Tue Jan 18, 2022 10:44 am
I stand corrected - never had a "modern" open car !
Posted: Tue Jan 18, 2022 1:49 pm
Two options: Use a slot head screw or get a carriage bolt, file off the corners a bit. Either way just so it will match.
Posted: Tue Jan 18, 2022 5:57 pm
by Rich Eagle
Some more pictures to ponder.
