Model T mystery Puller Tool
Topic author - Posts: 4
- First Name: Sam
- Last Name: Hotton
Anyone know what this Puller Tool is for?
I think it's Model T, but not sure for pulling what?
It sort of looks like a Hub Puller, but the Model T ones I've seen just screw on.
It's got a number on it that starts with " T " which makes me think it's a Model T tool.
The number looks like "T266" or "T288", etc. I don't know, it's hard to make out.
The opening slot width is a loose 2-1/16" wide.
Anybody got any ideas on what it's for?
Re: Model T mystery Puller Tool
It might be a puller for 26-27 hubs with wire wheels?
- First Name: Sam
- Last Name: Hotton
OK Norm, that's a possibility I hadn't thought of!
Can anyone confirm this is what it is?
- MTFCA Number: 14972
- MTFCI Number: 15411
Not like any Ford tools illustrated in any of the Ford literature I've seen.
- MTFCA Number: 52564
Could be Model A hub puller.
1920 Dodge touring
1920 Dodge touring
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
A better design of an original with the upper web bridge but it appears to be a 1926/27 hub puller for wire wheel hubs.
- First Name: Sam
- Last Name: Hotton
I seem to remember that Model A & 26/27 Model T with wire spokes used the same rear hub puller?
Anyone know if this is correct?
The Ford puller for wire wheel hubs was a massively proportioned two-fingered affair and sported a "5-Z-1172" number
If this is a tool for a Model T, it is an aftermarket tool, and very lightly proportioned for the job.
NH Full Flow Float Valves
- First Name: Ed
- Last Name: Martin
It looks the same as a T70 Model A Ford rear hub puller sold on tbay
https://www.ebay.com/itm/184904602595?n ... 7675.l2557
Side note; There were two different Model A hub pullers, to fit the flange or groove type hub. The distance between the sides of the puller where it slides on would be different between the two styles.
1920 Dodge touring
1920 Dodge touring
- First Name: Sam
- Last Name: Hotton
My Tool is a pretty hefty & solid tool.
It weighs a decent 7.1 Lbs !
