1913 body braces
Topic author - Posts: 362
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
- MTFCA Number: 50484
- MTFCI Number: 24737
1913 body braces
About a week ago there was a thread , in which Hap Tucker posted info on the reinforcing brackets that were necessary
for the weak design on some 1913 bodys
viewtopic.php?f=2&t=26387
I would like to see the information that wold picture the brackets.possibly someone can find this in the archives and post
Thanks Rich
Thanks Rich
- First Name: Rich
Re: 1913 body braces
The info was from letter number 395 and it referenced T5434 and sketch T5638
- MTFCA Number: 4838
- MTFCI Number: 115
Don't have copy of those part #s, but Bruce's C-D Ency. (another reason to buy this $50 super C-D) has picture of the frame bracket and the reinforcement body bracket installed on a body. And attached is copy of Ford instructions for install.
- MTFCA Number: 14972
- MTFCI Number: 15411
I have a '13 Touring in the shop currently with those rear support brackets & the owner has access to a very substantial machine & fabrication shop and is considering doing a limited run of these if there's interest.
- First Name: Rich
- Last Name: Bingham
- Last Name: Seress
- MTFCA Number: 27707
Someone is selling a set of support brackets on this website on parts.
- MTFCA Number: 1219
I sold these a few years ago. This shows common wear and abuse and possibly some detail.
- Last Name: Eyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
I need a pair. There are two widths of sills if I remember correctly.
- First Name: Rich
Here is the information that I was referring to this morning:
JAN 28 1913 Acc. 575, Letter 395, Ford Archives
T-5637 Body Reinforcing Bracket Bolt. "Four required, Touring Car, 1913."
T-5453 Body Reinforcing Bracket. New Drawing. "Two required, Touring Car, 1913."
T-5638. Sketch showing location of Body Reinforcing Bracket. "We have made this sketch for the purpose of showing customers who are having trouble with the touring car bodies how the trouble can be overcome. The material has been ordered and we will be able to supply same in the near future. For your information will state that the construction of the body has been improved upon and undoubtedly will not need this reinforcement as soon at the change can be brought about. We will therefore order only enough material of the above parts as shown on sketch to take care of the bodies which have already been built."
FWIW, My Jan 2, '13 car sports a set of these, and I believe them to be original to the car
NH Full Flow Float Valves
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet
- MTFCA Number: 28
- MTFCI Number: 10546
Scott, The "Ford Sales Bulletin", dated May 1913 states that these braces are now available to dealers. My January 1913 touring has the frame brackets that are bolted to the frame. There is no doubt that Ford knew there was a problem with the weakness of the sills and these braces were retrofitted to earlier (pre-May 1913) cars. I hope this helps. Russ Furstnow
- First Name: Bob
- Last Name: McDaniel
- MTFCA Number: 28428
January 1913 touring.
- First Name: Gerald
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T Touring + 1923 Model T Touring
- MTFCA Number: 31853
Could I join the list for two sets? Have you put out a call for those interested?
Thank you btw!!
The fella is coming to the shop today - I'll ask him about producing some.
Hi Rajo, if you strike out with you guy, I have a person I can speak to. I'd need a template and then a list of who wants them with sill measurements for each. Let me know what you think.
Hi RajoRacer,
Did you ever have luck with making up some braces? If so, I can be reached at gefrobinson@yahoo.com
Fella's picking up the T on Monday and said he's going to make patterns after he gets it back to his shop - he's not one to drag his feet on a project - I'll attempt to stay on top of it.
My friend has removed a support bracket and is currently making patterns - if anyone might be interested, let me know. I have no idea on production costs as of yet but he mentioned having a dozen sets made up..
- Last Name: Eyre
I would be interested in a set I think.
Mark Eyre meyre14t@yahoo.com
- Last Name: Carter
- * REQUIRED* Type and Year of Model Ts owned: 1913, 1919, 1924
- MTFCA Number: 28125
- MTFCI Number: 21824
I would be interested.
John
John
He's coming out today to retrieve his other chassis I got running for him - I'll check on the brackets progress !
