Looking For Stop Light Switch Instructions
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Fri Jan 21, 2022 12:18 pm
Does anyone have the installation instruction sheet for the Fun Projects Stop Light Switch?
Could you please post or emil me a copy?
Thanks.
Respectfully Submitted,
Be_Zero_Be
MTFCA Number: 14972
MTFCI Number: 15411
Re: Looking For Stop Light Switch Instructions
Post by RajoRacer » Fri Jan 21, 2022 12:37 pm
I believe I do Bob - going out to the shop in a bit.
* REQUIRED* Type and Year of Model Ts owned: '23 cutoff, '25 touring, '27 touring
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Jan 21, 2022 12:54 pm
Bob
Here you go. These are instructions.
IMG_7100 (600x450).jpg (115.98 KiB) Viewed 1487 times
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Fri Jan 21, 2022 3:47 pm
Thanks Dan & Steve.
Be_Zero_Be
OldFordGuyDan
First Name: Daniel
Last Name: Adcock
* REQUIRED* Type and Year of Model Ts owned: Several
MTFCA Number: 31975
MTFCI Number: 10468
Post by OldFordGuyDan » Sat Jan 22, 2022 8:50 am
I use a motorcycle brake light switch on all my Ts and work very well. Easy bracket to make even I can do it!
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sat Jan 22, 2022 2:05 pm
Dan...is there any info and/or pics you could post? Seems like the venerable "fun projects switch" will be no more. I keep hearing from certain people "oh its being made" but never seems to surface. Luckily I found an un-needed couple of F.P. switches to finish my fleet so at least I'm good. But others may be interested in your design.
Post by TRDxB2 » Sat Jan 22, 2022 4:01 pm
Would like to see what has been done too. These look they could be used very easily
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Post by BE_ZERO_BE » Sat Jan 22, 2022 5:35 pm
Google "Starter Button Switch".
A large number of booted switches will come up.
Most under $10.
Be_Zero_Be
