Going Dry for More Power
Topic author - Posts: 5339
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
This project was on the back burner for quite awhile. Was suppose to be used for a Model T project I was building to go to Bonneville Salt Flats for an attempt at 220 MPH in a Model T. The good ole boys and their stupid rules and interpretations, No Thanks! A stock Model T transmission with all that weight is a power stealing hog and also steals fuel mileage. Going dry as the Dodge Bros suggested to Henry Ford would gain better fuel mileage and power. Well.., He did it on the Model A! Going dry clutch with a Mustang SVO 5 speed, in front..., a Joe Gemsa head with a Super Stroker Balanced Skat cranked engine. This only took 10 hours today since it is a one off proto type.., more to come later. That pile of 6061 series aluminum and all the attachment hardware is only $900.00 now. Frickin' OUCH! Slow cutting 1" Billet!
All the Best,
Hank
All the Best,
Hank
- First Name: Les
- Last Name: Schubert
Re: Going Dry for More Power
Looks great. Nice to see I’m not the only screwball!!
This casting takes any ford transmission from a 2.9 l or smaller engine-
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Screw balls are a special club Les. SSSShhhhh!
The clutch and transmission are one of the unique differences on a Model T than other cars. If you want dry, why don't you look for a Dodge or Chevy? Or if you want more speed look for an early Ford V8?
- MTFCA Number: 51486
? Same reason that dude put a 427 FE in an AC Cobra.
- First Name: Les
The one I have pictured is staying with oiled multidisc clutches! Borg Warner T35 automatic from a 68 Cortina. Couple of nice features are the air cooled torque converter and a cable kick down.
I’ve done a couple of T engines using the T transmission with the flywheel NOT running in the oil. I oil the transmission from the inside with a drilled main shaft. Works great.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Why kill a good engine with an over heavy rotating device? Think how many crankshafts have been broken by out of balance conditions due to wear, metal fatigue, strain on bands , etc. Why do you accessorize a modern car or truck or keep buying a new one? Why do people put on Sure Stop Brakes? I would not for personal reasons and because I doubt there will be any replacement parts for them in 20 years or less. The rear disc rotors and calibers are not for a passenger car but for trailers (Non People Carrying Vehicles) and the master cylinder is for Off Road Use Only. Because you can and so can I if I like. But if a fatality occurs and a crash investigation is performed, I will guarantee you, someone modified their vehicles original design and did not read the fine print in their insurance policy. Improvements with logic is best, doing what someone is trying to sell you is buyer beware. Let's face it..., Metal fatigue will stop you in your tracks or kill you and at the current rate of our members whom have passed that used to produce nice replacement parts, we as car people have about 20 years left in having fun so to say.
Have fun, I am!
Humbled Hank
P.S. Les.., Looking Good! Dad's 1914 has the wet clutch only with a 1937 Chevy top loader.., works sweet!
Have fun, I am!
Humbled Hank
- First Name: Erik
- Last Name: Barrett
A flathead model T has run 200 mph at Bonneville. Five main crank with a girdle and turbocharged I believe. That Gemsa head will make more power but you may need to supercharge it to get into the 200 club. I would be happy to help you in the endeavor.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Thanks Erik, but scraped the idea. Was going with the engine in the rear with a special aero designed body. Dr Gary Flandro, Aeronautical Engineer, offered wind tunnel test for the body. Already made the girdles, etc, but wanted to stay away from a super charger, turbo, or NOS. Final drive would have been a sliding variable disc.
Hank
Hank
I'd think a MILD nitrous system and a scat crank/rods would make a nice, stock looking fast T. 35 HP at 2100 (?) Or maybe a belt-driven supercharger? Forged pistons?
- First Name: DAN
- Last Name: MCEACHERN
A little off subject here, but SCTA/BNI rules are intended for one thing- to keep everyone safe. Yea, some of the rules may seem draconian, but lots of folks have walked away from fires and crashes at over 200 MPH because of those rules and requirements. Enjoy your cars, whatever you do.
- First Name: Les
Henry
Like you, I had thoughts about Bonneyville and other events but I was warned that my ideas would not be acceptable. So I will just carry on at home.
- Last Name: Codman
I wish you luck in your quest for 220, but I will believe it when I see it. In order to go 220 the chassis and body will not be Model T. I simply don't believe that you can get enough power out of a T engine that is normally-aspirated and without nitrous. I would love it if you can prove me wrong.
- First Name: Les
Gemsa head
The oil pan And the block
The intake manifold for 2 V8 carburetors
- First Name: Les
The block
- Last Name: Codman
My Model T engine has three main bearings; yours has five. What year did a Model T Ford engine have five main bearings?
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
- MTFCA Number: 13996
Looks like the same year they went to aluminium blocks and four intake ports.
Harry
Harry
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Well.., there you go.., Les made it!
Oddly enough they even made them in the day! Years back on top fuel dragsters a guy lost a bet with me. He had to buy me Corona beer and Crown Royal for a year. Said I could not get the car over 300 mph! It Did 305 mph! A natural aspirated engine with the right body can do miracles! You can even install a rotation catch in between 1&2.., and 3&4. Cool old stuff in engineering!!!!
Hank
Hank
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Well another 10 hour day that was very productive!!!!!
The duct tape holding the wing reinforcements on is Gorilla Tape..., All Good!
- First Name: Les
Looks GREAT!
- MTFCA Number: 14383
Keep um coming. Do you smell that? Like burning rubber smell?
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
A few years back I sold a cast aluminum pan and adapter that was used to mount a C4 transmission to the Model T Engine. A popular conversion at one time as I understand it. Engine was built by Orville Enyeart and owned by Andy Mounce. I believe LaRue Thomas is responsible for these casting.
- Last Name: Codman
Please don't take this as criticism, and I wish you the best of luck in your quest, but the chassis won't be Model T, the body won't be Model T, and the engine isn't Model T. How will this car be a Model T? With all due respect to someone who is far more skilled then I, but this project reminds me of my axe that was once owned by George Washington; it has had three new handles, a new head, and two new wedges, but it is George Washington's axe.
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
The “Model T” that ran over 200mph at Bonneville used a Model T block and front cover plate. The extra main bearings for the five main bearing crank was a lump of aluminum to support bearings 2 and 4. The bearing 1, 3 and 5 sat in the T block. Incidentally the crank was made in San Diego .
On the first year the streamliner had a two speed gear box. On the second year the car had a five speed gearbox and a very custom 1.9:1 crown wheel and pinion. I believe that was made in the US South. The aluminum cylinder head was custom, incidentally machined by the very talented driver.
After runs were over, the crew were given a picture of the car signed by the driver and Bill Ford.
Tony Bowker
La Mesa, California
La Mesa, California
- First Name: Dennis
- Last Name: Seth
Clayton Paddison ran his Model T at Bonneville salt flats
He was also featured on Jay Leno's Garage series.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Well, got 6 hours playtime in today at Frank N. Steins playhouse!
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
Looking good Hank! Nice to see you still building these things.
Lots of non-productive criticism in this topic.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Thanks Shane!
Everyone is entitle to their opinion and I know those that do not appreciate what I am doing, BUT! My car, My time, My money and My way of having fun. I have every single part to bring this 1927 Roadster Pick Up back to original fully restored, everything is just "Bolt On". Yes, overboard but the proving to myself as well as the theory of gaining a lot of power and fuel efficiency. If product improvement is a taboo.., then let's put back in the car, 2 piece valves, heavy rods, white metal rear end thrust bearings, and etc. If those that criticize bumble on their words.., then they have pink panties on their clothes line behind a locked gate and they are the only ones that live there. Mom said it best.., " If you can not say something nice.., keep your mouth shut"!
- First Name: Les
Very nice!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Thanks Les!!!
I still need adult supervision, Dad after a nap with the mouse getter. He will be a big 90 Feb 2, 2022. Glad I still have him.., he still inspirer's me every day!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Well another super day at Frank's playhouse. Did a lot of calculating for this and that and welding. The welds look rough and are cold so to say to control any warping. I regrind them, then weld them smooth with a copper backing bar inside and out. When it is all done will look like cast aluminum after texture and paint is applied.
Installed a cross over tube (orange tubing) for the oil pressure line coming from the oil pump on the other side. Also two "Shotgun" style low air cooling tubes for the oil. These have worked great in the past, and keeps the oil about 20 degrees cooler while cruising. Still have baffles to fabricate and oil pick up...., waiting on some 3/8" plate for the back catch of the oil pan as this will hold torque as required. 8 hours spent in THERAPY!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Inspection plate reused, just shorted 2 5/8" to compensate for the drag link clearance.
- First Name: Mike
- Last Name: Howell
- * REQUIRED* Type and Year of Model Ts owned: 23 Speedster, 26 Roadster
- MTFCA Number: 28354
The oil cooler tubes are a neat concept! I'd like to add the idea to a project I'm working on if you don't mind, Hank.
"I refuse to join any organization that would have someone like me as a member." Mark Twain
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
GO FOR IT MIKE!!!!!!!
- First Name: Mike
- Last Name: Howell
Consider the idea shamelessly stolen!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Or borrowed from a friend but your memory is getting fuzzy and you forgot his name!!!!!!!!
- First Name: Mike
- Last Name: Howell
Always credit where due. Thanks for the thread.....
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
4 hours of play time today, but productive!
Setting and checking Crank Stroke Throws.
Baffling isn't it. Must have baffles in long oil pans or possible momentary pump starving (cavitation) could occur in hard braking, cornering, etc. In high constant speed engines running above 4,000 RPM's, a windage tray that profiles the crankshaft and rotating assembly is used to prevent oil striking hard into the sump which in turn causes air in the oil, causing really bad cavitation making an oil pump seize up.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Had about 8 hours playtime or therapy which ever works!!!!!!
Hank
Hank
- Last Name: Warren
Very ambitious project, LOVE IT!! As always superior workmanship jw
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Too cold outside to plant banana trees so back to the playhouse!
Reenforce may look extreme on the pan but controlling torque and letting the clutch take the hit is what I am doing. Using the plane on two halves are better than one theory.
Since the rear crankshaft flange adapter is 4 1/4", doing a two piece seal retainer housing. Over the top, but wanted it where no questions later, should have, would have. These housings are used in very high endurance, top fuel, Le Mans, aircraft, etc engines. Never had one leak. Pre-assembly done and everything is going as planned 8 hours later.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Sometimes in the south we dig out ultra precise equipment to get ur dun! We normally do not show off..., "You know what I mean Vern"! Hold tat dar hand steady!
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Looks good Hank. Your pretty good with the electric drill and concrete saw .
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Another day of play so to say. Here are some simple methods for dimpling a pan for stroker clearances. I go a little more than needed as I more clearance is better in case something comes loose while in motion. Better to hear a rod knock than for it to strike the cases. Serious damage is a sure thing then.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Heres you a good way to make and store prints/templates. Go to your nearest place that forms steel roofs, get a piece in blue or any other color (normally 41" width before extrusion), transfer your prototypes by scribing and transfer punches, drill holes and cut out edges. We use a place in Europe that photographs our templates with a precision scale square. It then automatically writes the program with only the program writer putting in hole sizes and threads.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Busy day making master templates by transfer punch and scribe. Resting hands too after cutting. I am not going to make these templates or produce the adapter for sale, I am passing this on to two of our members and will let them release info as they see fit. No, I will not release their names out of respect.
- First Name: Les
That’s a really interesting idea for patterns!!
I like it
I like it
- First Name: Les
A suggestion. Take those panels and get them scanned and then they can be saved to a USB key.
- First Name: Craig
- Last Name: Raynor
Just saw this and could not stop reading , great project hope to hear it running some day .
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Les,
We use a company in Europe that does our other photo scan with a precision scale square for reference, then it is converted to a CNC program. I am not going to produce but I am passing on the torch as stated before. Just like to be organized and preserve for another day. The pattern I purchased from you a few years back inspired me to take this on.., Thanks! The larger bell housing plate (known as plate #3) and flywheel hub will be inner changeable to accommodate any other transmission as one sees fit to use.
You will Craig, You will!
All the Best,
Hank
All the Best,
Hank
- First Name: warwick
- Last Name: preval
- * REQUIRED* Type and Year of Model Ts owned: 25 tr 22 coupe
- Board Member Since: 2014
YEAH me to
- First Name: Neil
- Last Name: Martin
Warwick, Just stick with your Toyota.......n
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Long day of welding with plenty of cooling cycles. No warping.., PERIOD! Dead squared. Using round stock as a transition from thicker to thinner steel I was shown by an old boy in England. Really does a beautiful job. Used 1/32" shims to simulate the thickness of the gaskets. When I released the tension on all the bolts.. they all came out by hand after the metal was dead cold. A lot of sanding but worth it!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
- First Name: Les
Very nice!
Craftsmanship! All I can say Hank.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
20 hours later, 3 sets of master templates finished. Now on to material/hardware list with findings and instructions.
Final fitting after bead blasting and installing bungs for oil system with baffles, etc.
Decided to install a holding sump in the front for the timing gear to keep them wet. Will have a sprayer on the side.
The aluminum plate is a little heavy for my TIG, so letting a friend install his magic on it.
- First Name: Les
VERY nice!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Did a pre-fit double check for clearance with the Skat crank. Needed a little more in the front for safety. Will blend in later. Modified the dimple bars for either Model A mod or Skat Stroker mod. Adapter fits nice and snug.
Looks beefy Hank. I wish I had that kind of knowledge. Watching and learning here in Indiana.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Thanks Dallas.., Just trying to pass on what life teaches us! Since the engine's weight is being support by the pan, and adding a mid section (bell housing), the pan needs extra to counter horse power/torque since it is not being supported by the block like later engines.
Hank
Hank
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Well after about 3 hard days labor it is shaping in nicely. Weld, grind, do again. Then glaze over with epoxy and sand, sand, and sand. Worth it, now comes the texture coat , painting and coating the inside.
Tesla and others said it best..., "If you can imagine something whether in principle or art.., then gain knowledge and pursue"!
- First Name: Gerrit
- Last Name: Marks
I'm happy if I can make 35 mph on the flats. After that I get scared. Nice little fella on the seat, looks like a good companion. Good luck with your project, be safe, Gerrit
- First Name: Les
BEAUTIFUL job!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Thanks Les and Others!
I had a Great experience years back in my military career. I was selected for an exchange/collaboration team in adapting US aircraft weaponry to NATO forces and vise versa. Talk about R & D! Prototypes, experimental, camera mounting, etc. You had to fabricate an item within about 48 hours in time for the test, Best one year duty I ever had!
Humbled Hank
Humbled Hank
- Last Name: Morsher
Are you ready for my next set of drawings? Hope I’m not holding the project up
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Clean. clean, and more cleaning! hand sanding inside, double wipe with acetone, then spray two heavy coats of Gyptal with acetone as a reducer. Never had a peel. Don't forget oil injection to the front timing gears.
Starting the open driveshaft system using a conventional Model T rear end with mechanical brakes.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Tim, I can read your chicken scratch just as good as mine Brother!
- First Name: Les
Hank
My version of the pinion shaft for a open drive shaft.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Looks Great Les, Mine will be similar!!!!!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Will after sanding and prep.., here comes the texture and paint!
Using old flat washers to prevent texture paint (Truck Bed Liner Spray) and plug off holes. Gives a machined after casting effect plus keeps your bolts after tightening from making a mess.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
TAH DAH!!!!!!
....wow....
NH Full Flow Float Valves
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Coming from you Scott..., WOW back at you! Thank You!
Humbled Hank
Humbled Hank
- First Name: Ned
- Last Name: Lloyd
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe, 1924 huckster
- MTFCA Number: 0
Absolutely beautiful work,…… I am duly impressed!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Well..., Perfect fit! I be Happy! On to the rear end mods for the open drive shaft system. Have to control torque, as one of my old professors used to say.., "it is your friend in power transmitting.., but a scorn woman from hell if not kept happy and in place"!
- Last Name: Plowman
- * REQUIRED* Type and Year of Model Ts owned: 1926 cut down tourer
This is great work Hank, thanks for sharing
1926 T Touring cut down with tray back "The Gin Runner"
1926 TwinT straight 8 project
1928 Indian Chout
1940 Indian 640 Stroker
1928 Indian Chout
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Thank You Steve! Here's more.
Going a little different from Les's mod. His is great, no doubt. I want to hold tight as I believe the weak link is in the casting of thin material in the housings, from torque tube/radius rod absorption to a "torque wing" retainer and back truss (holding closer to the source with a strong arm).
Using tubes and old flat washers will save you time in clean up from weld spatter, coming in hot on the welds.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Now that the non accessible area is cleaned up, on to the next section. Welds are built up as I will shape into a casted effect of webs when finished. Looks like a shop class project went bad! LOL!
Bending plate steel 1/4" is made easy if you have a shop press, drill press V block, small piece of steel!
You will see why this support becomes important in my design later, catching/retaining torque. If there is a failure, in theory, no damage to the internal components (Safety Break Away)! Using a still available Winters Quick Change yoke modified with mild steel square keyways with a retaining nut. That front snout has two back to back roller bearings in front of a Fun Project adjustable preload pinion bearing. Stayed tune to this channel for more fun with Dr Frank N. Stein, aka..., Humbled Hank.
Pretty stuff coming soon!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
A good day in the playhouse. Machined and broached the yoke, machined polyurethane to fit behind the yoke as a harmonic silencer (straight cut gears love to resonate noise causing deep harmonics, creating metal fatigue). Grinding down the welds, etc.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
- First Name: Les
Some very interesting stuff!
- Last Name: Rogers
Hank- you're awful brave to post some many pictures of such shoddy work!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
It will improve Tim I promise! I had to put the pixies in a time out! Thanks Man! LOL
Hank
Hank
You sure are good with that file and hand drill Hank! is that an entire roll of red tape?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Dallas you better quit giving away my master craftsman secrets..., dim dar be ah fighting' words mister! LOL
OK..., Now you can get a better picture how this will work! Front torque arm/truss with a rear truss! They will tie into the rear link supports to be determined later.
- First Name: Les
A very interesting approach. Thank you for the posting
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Another long productive day!!!!!!
- First Name: Les
Interesting approach. Looking forward to more
- Last Name: C
- MTFCA Number: 52098
There should be more to this by now. Are you slacking off? Sabine and I were not there that long and I have not been calling you that much!!
Socialism is resentment disguised as compassion enforced by tyranny disguised as tolerance.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Other Priorities as the Grand God Children from England are planning on coming over! Plus Honey-Do's!
Hank
Hank
- Last Name: C
Same problem, New Kitchen cabinets showed up and I was forced to stop on Scarlotte O'Hair but has her new trans and rear end from you installed now it just putting ALL the other pieces back together. Killing me running to the store in a normal car!Henry K. Lee wrote: ↑Sat Apr 09, 2022 10:04 amOther Priorities as the Grand God Children from England are planning on coming over! Plus Honey-Do's!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Well..., After a few delays, ie, my welder not big enough, brother Rick Rice tried to, not big enough, found some really good young guys in Chattanooga that did me proud! And as a bonus.., the wife went to Florida for a week! Goof off time.., I meant playtime.
The plates dialed in on the money with the crankshaft..., could not be happier than that. Had to machine a dumbing shaft for the dialing but part of the fun. ENJOY!
Hank
Hank
I really enjoy seeing nice fabrication work.
- First Name: Les
Looks great!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Decided to press my good fairy luck on this project. Mounted the flywheel, bell housing, and starter then connect power to check flywheel run out..., within 0.0002! Holy Crap..., me happy!
- First Name: Les
Looks great.
This could be a tv show!
