Going Dry for More Power
Posted: Fri Jan 21, 2022 6:52 pm
by Henry K. Lee
This project was on the back burner for quite awhile. Was suppose to be used for a Model T project I was building to go to Bonneville Salt Flats for an attempt at 220 MPH in a Model T. The good ole boys and their stupid rules and interpretations, No Thanks! A stock Model T transmission with all that weight is a power stealing hog and also steals fuel mileage. Going dry as the Dodge Bros suggested to Henry Ford would gain better fuel mileage and power. Well.., He did it on the Model A! Going dry clutch with a Mustang SVO 5 speed, in front..., a Joe Gemsa head with a Super Stroker Balanced Skat cranked engine. This only took 10 hours today since it is a one off proto type.., more to come later. That pile of 6061 series aluminum and all the attachment hardware is only $900.00 now. Frickin' OUCH! Slow cutting 1" Billet!
All the Best,
Hank
Re: Going Dry for More Power
Posted: Fri Jan 21, 2022 7:36 pm
by Les Schubert
Looks great. Nice to see I’m not the only screwball!!
This casting takes any ford transmission from a 2.9 l or smaller engine
Posted: Fri Jan 21, 2022 7:59 pm
by Henry K. Lee
Screw balls are a special club Les. SSSShhhhh!
Posted: Fri Jan 21, 2022 8:39 pm
by Norman Kling
The clutch and transmission are one of the unique differences on a Model T than other cars. If you want dry, why don't you look for a Dodge or Chevy? Or if you want more speed look for an early Ford V8?
Posted: Fri Jan 21, 2022 8:41 pm
by TXGOAT2
? Same reason that dude put a 427 FE in an AC Cobra.
Posted: Fri Jan 21, 2022 9:22 pm
by Les Schubert
The one I have pictured is staying with oiled multidisc clutches! Borg Warner T35 automatic from a 68 Cortina. Couple of nice features are the air cooled torque converter and a cable kick down.
I’ve done a couple of T engines using the T transmission with the flywheel NOT running in the oil. I oil the transmission from the inside with a drilled main shaft. Works great.
Posted: Fri Jan 21, 2022 10:36 pm
by Henry K. Lee
Why kill a good engine with an over heavy rotating device? Think how many crankshafts have been broken by out of balance conditions due to wear, metal fatigue, strain on bands , etc. Why do you accessorize a modern car or truck or keep buying a new one? Why do people put on Sure Stop Brakes? I would not for personal reasons and because I doubt there will be any replacement parts for them in 20 years or less. The rear disc rotors and calibers are not for a passenger car but for trailers (Non People Carrying Vehicles) and the master cylinder is for Off Road Use Only. Because you can and so can I if I like. But if a fatality occurs and a crash investigation is performed, I will guarantee you, someone modified their vehicles original design and did not read the fine print in their insurance policy. Improvements with logic is best, doing what someone is trying to sell you is buyer beware. Let's face it..., Metal fatigue will stop you in your tracks or kill you and at the current rate of our members whom have passed that used to produce nice replacement parts, we as car people have about 20 years left in having fun so to say.
Have fun, I am!
Humbled Hank
P.S. Les.., Looking Good! Dad's 1914 has the wet clutch only with a 1937 Chevy top loader.., works sweet!
Posted: Sat Jan 22, 2022 12:31 am
by Erik Barrett
A flathead model T has run 200 mph at Bonneville. Five main crank with a girdle and turbocharged I believe. That Gemsa head will make more power but you may need to supercharge it to get into the 200 club. I would be happy to help you in the endeavor.
Posted: Sat Jan 22, 2022 6:15 am
by Henry K. Lee
Thanks Erik, but scraped the idea. Was going with the engine in the rear with a special aero designed body. Dr Gary Flandro, Aeronautical Engineer, offered wind tunnel test for the body. Already made the girdles, etc, but wanted to stay away from a super charger, turbo, or NOS. Final drive would have been a sliding variable disc.
Hank
Posted: Sat Jan 22, 2022 9:52 am
by TXGOAT2
I'd think a MILD nitrous system and a scat crank/rods would make a nice, stock looking fast T. 35 HP at 2100 (?) Or maybe a belt-driven supercharger? Forged pistons?
Posted: Sat Jan 22, 2022 12:23 pm
by Dan McEachern
A little off subject here, but SCTA/BNI rules are intended for one thing- to keep everyone safe. Yea, some of the rules may seem draconian, but lots of folks have walked away from fires and crashes at over 200 MPH because of those rules and requirements. Enjoy your cars, whatever you do.
Posted: Sat Jan 22, 2022 1:02 pm
by Les Schubert
Henry
Like you, I had thoughts about Bonneyville and other events but I was warned that my ideas would not be acceptable. So I will just carry on at home.
Posted: Sat Jan 22, 2022 2:14 pm
by John Codman
I wish you luck in your quest for 220, but I will believe it when I see it. In order to go 220 the chassis and body will not be Model T. I simply don't believe that you can get enough power out of a T engine that is normally-aspirated and without nitrous. I would love it if you can prove me wrong.
Posted: Sat Jan 22, 2022 4:04 pm
by Les Schubert
Gemsa head
The intake manifold for 2 V8 carburetors
The oil pan
304E5AA1-AC4A-4093-9476-9220C46533C9.jpeg[/attachment [attachment=0]B3E2FF41-E147-4F29-AF35-C0D13DBFD580.jpeg
And the block
Posted: Sat Jan 22, 2022 4:18 pm
by Les Schubert
The block
Posted: Sat Jan 22, 2022 5:27 pm
by John Codman
My Model T engine has three main bearings; yours has five. What year did a Model T Ford engine have five main bearings?
Posted: Sat Jan 22, 2022 5:49 pm
by Harry Lillo
Looks like the same year they went to aluminium blocks and four intake ports.
Harry
Posted: Sat Jan 22, 2022 6:02 pm
by Henry K. Lee
Well.., there you go.., Les made it!
Oddly enough they even made them in the day! Years back on top fuel dragsters a guy lost a bet with me. He had to buy me Corona beer and Crown Royal for a year. Said I could not get the car over 300 mph! It Did 305 mph! A natural aspirated engine with the right body can do miracles! You can even install a rotation catch in between 1&2.., and 3&4. Cool old stuff in engineering!!!!
Hank
Posted: Sat Jan 22, 2022 6:43 pm
by Henry K. Lee
Well another 10 hour day that was very productive!!!!!
The duct tape holding the wing reinforcements on is Gorilla Tape..., All Good!
Posted: Sat Jan 22, 2022 7:36 pm
by Les Schubert
Looks GREAT!
Posted: Sat Jan 22, 2022 7:44 pm
by speedytinc
Keep um coming. Do you smell that? Like burning rubber smell?
Posted: Sun Jan 23, 2022 7:57 am
by henryford2
A few years back I sold a cast aluminum pan and adapter that was used to mount a C4 transmission to the Model T Engine. A popular conversion at one time as I understand it. Engine was built by Orville Enyeart and owned by Andy Mounce. I believe LaRue Thomas is responsible for these casting.
Posted: Sun Jan 23, 2022 11:01 am
by John Codman
Please don't take this as criticism, and I wish you the best of luck in your quest, but the chassis won't be Model T, the body won't be Model T, and the engine isn't Model T. How will this car be a Model T? With all due respect to someone who is far more skilled then I, but this project reminds me of my axe that was once owned by George Washington; it has had three new handles, a new head, and two new wedges, but it is George Washington's axe.
Posted: Sun Jan 23, 2022 11:58 am
by TonyB
The “Model T” that ran over 200mph at Bonneville used a Model T block and front cover plate. The extra main bearings for the five main bearing crank was a lump of aluminum to support bearings 2 and 4. The bearing 1, 3 and 5 sat in the T block. Incidentally the crank was made in San Diego 😊.
On the first year the streamliner had a two speed gear box. On the second year the car had a five speed gearbox and a very custom 1.9:1 crown wheel and pinion. I believe that was made in the US South. The aluminum cylinder head was custom, incidentally machined by the very talented driver.
After runs were over, the crew were given a picture of the car signed by the driver and Bill Ford. 😊
Posted: Sun Jan 23, 2022 3:02 pm
by perry kete
Clayton Paddison ran his Model T at Bonneville salt flats
He was also featured on Jay Leno's Garage series.
Posted: Sun Jan 23, 2022 7:14 pm
by Henry K. Lee
Well, got 6 hours playtime in today at Frank N. Steins playhouse!
Posted: Sun Jan 23, 2022 7:24 pm
by Shane Lach
Looking good Hank! Nice to see you still building these things.
Lots of non-productive criticism in this topic.
Posted: Sun Jan 23, 2022 7:48 pm
by Henry K. Lee
Thanks Shane!
Everyone is entitle to their opinion and I know those that do not appreciate what I am doing, BUT! My car, My time, My money and My way of having fun. I have every single part to bring this 1927 Roadster Pick Up back to original fully restored, everything is just "Bolt On". Yes, overboard but the proving to myself as well as the theory of gaining a lot of power and fuel efficiency. If product improvement is a taboo.., then let's put back in the car, 2 piece valves, heavy rods, white metal rear end thrust bearings, and etc. If those that criticize bumble on their words.., then they have pink panties on their clothes line behind a locked gate and they are the only ones that live there. Mom said it best.., " If you can not say something nice.., keep your mouth shut"!
Posted: Sun Jan 23, 2022 7:52 pm
by Les Schubert
Very nice!
Posted: Sun Jan 23, 2022 8:01 pm
by Henry K. Lee
Thanks Les!!!
I still need adult supervision, Dad after a nap with the mouse getter. He will be a big 90 Feb 2, 2022. Glad I still have him.., he still inspirer's me every day!
Posted: Mon Jan 24, 2022 6:52 pm
by Henry K. Lee
Well another super day at Frank's playhouse. Did a lot of calculating for this and that and welding. The welds look rough and are cold so to say to control any warping. I regrind them, then weld them smooth with a copper backing bar inside and out. When it is all done will look like cast aluminum after texture and paint is applied.
Installed a cross over tube (orange tubing) for the oil pressure line coming from the oil pump on the other side. Also two "Shotgun" style low air cooling tubes for the oil. These have worked great in the past, and keeps the oil about 20 degrees cooler while cruising. Still have baffles to fabricate and oil pick up...., waiting on some 3/8" plate for the back catch of the oil pan as this will hold torque as required. 8 hours spent in THERAPY!
Posted: Mon Jan 24, 2022 6:54 pm
by Henry K. Lee
Inspection plate reused, just shorted 2 5/8" to compensate for the drag link clearance.
Posted: Mon Jan 24, 2022 7:40 pm
by Mike Howell
The oil cooler tubes are a neat concept! I'd like to add the idea to a project I'm working on if you don't mind, Hank.
Posted: Mon Jan 24, 2022 7:59 pm
by Henry K. Lee
GO FOR IT MIKE!!!!!!!
Posted: Mon Jan 24, 2022 8:02 pm
by Mike Howell
Consider the idea shamelessly stolen!
Posted: Mon Jan 24, 2022 8:07 pm
by Henry K. Lee
Or borrowed from a friend but your memory is getting fuzzy and you forgot his name!!!!!!!!
Posted: Mon Jan 24, 2022 10:48 pm
by Mike Howell
Always credit where due. Thanks for the thread.....
Posted: Tue Jan 25, 2022 8:06 pm
by Henry K. Lee
4 hours of play time today, but productive!
Setting and checking Crank Stroke Throws.
Baffling isn't it. Must have baffles in long oil pans or possible momentary pump starving (cavitation) could occur in hard braking, cornering, etc. In high constant speed engines running above 4,000 RPM's, a windage tray that profiles the crankshaft and rotating assembly is used to prevent oil striking hard into the sump which in turn causes air in the oil, causing really bad cavitation making an oil pump seize up.
Posted: Sat Jan 29, 2022 8:01 pm
by Henry K. Lee
Had about 8 hours playtime or therapy which ever works!!!!!!
Hank
Posted: Sat Jan 29, 2022 9:06 pm
by John Warren
Very ambitious project, LOVE IT!! As always superior workmanship jw
Posted: Sun Jan 30, 2022 4:53 pm
by Henry K. Lee
Too cold outside to plant banana trees so back to the playhouse!
Reenforce may look extreme on the pan but controlling torque and letting the clutch take the hit is what I am doing. Using the plane on two halves are better than one theory.
Since the rear crankshaft flange adapter is 4 1/4", doing a two piece seal retainer housing. Over the top, but wanted it where no questions later, should have, would have. These housings are used in very high endurance, top fuel, Le Mans, aircraft, etc engines. Never had one leak. Pre-assembly done and everything is going as planned 8 hours later.
Posted: Tue Feb 01, 2022 6:19 pm
by Henry K. Lee
Sometimes in the south we dig out ultra precise equipment to get ur dun! We normally do not show off..., "You know what I mean Vern"! Hold tat dar hand steady!
Posted: Tue Feb 01, 2022 8:45 pm
by Dallas Landers
Looks good Hank. Your pretty good with the electric drill and concrete saw .😁
Posted: Thu Feb 03, 2022 4:43 pm
by Henry K. Lee
Another day of play so to say. Here are some simple methods for dimpling a pan for stroker clearances. I go a little more than needed as I more clearance is better in case something comes loose while in motion. Better to hear a rod knock than for it to strike the cases. Serious damage is a sure thing then.
Posted: Thu Feb 03, 2022 4:54 pm
by Henry K. Lee
Heres you a good way to make and store prints/templates. Go to your nearest place that forms steel roofs, get a piece in blue or any other color (normally 41" width before extrusion), transfer your prototypes by scribing and transfer punches, drill holes and cut out edges. We use a place in Europe that photographs our templates with a precision scale square. It then automatically writes the program with only the program writer putting in hole sizes and threads.
Posted: Fri Feb 04, 2022 8:59 pm
by Henry K. Lee
Busy day making master templates by transfer punch and scribe. Resting hands too after cutting. I am not going to make these templates or produce the adapter for sale, I am passing this on to two of our members and will let them release info as they see fit. No, I will not release their names out of respect.
Posted: Fri Feb 04, 2022 10:30 pm
by Les Schubert
That’s a really interesting idea for patterns!!
I like it
Posted: Fri Feb 04, 2022 10:32 pm
by Les Schubert
A suggestion. Take those panels and get them scanned and then they can be saved to a USB key.
Posted: Sat Feb 05, 2022 4:56 am
by Craig Raynor
Just saw this and could not stop reading , great project hope to hear it running some day .
Posted: Sat Feb 05, 2022 5:35 am
by Henry K. Lee
Les,
We use a company in Europe that does our other photo scan with a precision scale square for reference, then it is converted to a CNC program. I am not going to produce but I am passing on the torch as stated before. Just like to be organized and preserve for another day. The pattern I purchased from you a few years back inspired me to take this on.., Thanks! The larger bell housing plate (known as plate #3) and flywheel hub will be inner changeable to accommodate any other transmission as one sees fit to use.
You will Craig, You will!
All the Best,
Hank
Posted: Sat Feb 05, 2022 5:48 am
by warwick_preval
YEAH me to
Posted: Sat Feb 05, 2022 5:48 pm
by Poppie
Warwick, Just stick with your Toyota.......n
Posted: Sat Feb 05, 2022 8:02 pm
by Henry K. Lee
Long day of welding with plenty of cooling cycles. No warping.., PERIOD! Dead squared. Using round stock as a transition from thicker to thinner steel I was shown by an old boy in England. Really does a beautiful job. Used 1/32" shims to simulate the thickness of the gaskets. When I released the tension on all the bolts.. they all came out by hand after the metal was dead cold. A lot of sanding but worth it!
Posted: Sat Feb 05, 2022 8:03 pm
by Henry K. Lee
Posted: Sat Feb 05, 2022 8:16 pm
by Les Schubert
Very nice!
Posted: Sat Feb 05, 2022 8:23 pm
by Dallas Landers
Craftsmanship! All I can say Hank.
Posted: Tue Feb 08, 2022 7:06 pm
by Henry K. Lee
20 hours later, 3 sets of master templates finished. Now on to material/hardware list with findings and instructions.
Final fitting after bead blasting and installing bungs for oil system with baffles, etc.
Decided to install a holding sump in the front for the timing gear to keep them wet. Will have a sprayer on the side.
The aluminum plate is a little heavy for my TIG, so letting a friend install his magic on it.
Posted: Tue Feb 08, 2022 8:11 pm
by Les Schubert
VERY nice!
Posted: Wed Feb 09, 2022 5:36 pm
by Henry K. Lee
Did a pre-fit double check for clearance with the Skat crank. Needed a little more in the front for safety. Will blend in later. Modified the dimple bars for either Model A mod or Skat Stroker mod. Adapter fits nice and snug.
Posted: Wed Feb 09, 2022 6:00 pm
by Dallas Landers
Looks beefy Hank. I wish I had that kind of knowledge. Watching and learning here in Indiana.
Posted: Wed Feb 09, 2022 7:11 pm
by Henry K. Lee
Thanks Dallas.., Just trying to pass on what life teaches us! Since the engine's weight is being support by the pan, and adding a mid section (bell housing), the pan needs extra to counter horse power/torque since it is not being supported by the block like later engines.
Hank
Posted: Mon Feb 14, 2022 8:55 pm
by Henry K. Lee
Well after about 3 hard days labor it is shaping in nicely. Weld, grind, do again. Then glaze over with epoxy and sand, sand, and sand. Worth it, now comes the texture coat , painting and coating the inside.
Tesla and others said it best..., "If you can imagine something whether in principle or art.., then gain knowledge and pursue"!
Posted: Mon Feb 14, 2022 9:57 pm
by 5 WoodenWheels
I'm happy if I can make 35 mph on the flats. After that I get scared. Nice little fella on the seat, looks like a good companion. Good luck with your project, be safe, Gerrit
Posted: Mon Feb 14, 2022 10:27 pm
by Les Schubert
BEAUTIFUL job!
Posted: Mon Feb 14, 2022 10:39 pm
by Henry K. Lee
Thanks Les and Others!
I had a Great experience years back in my military career. I was selected for an exchange/collaboration team in adapting US aircraft weaponry to NATO forces and vise versa. Talk about R & D! Prototypes, experimental, camera mounting, etc. You had to fabricate an item within about 48 hours in time for the test, Best one year duty I ever had!
Humbled Hank
Posted: Tue Feb 15, 2022 12:57 pm
by Dropacent
Are you ready for my next set of drawings? Hope I’m not holding the project up
Posted: Wed Feb 16, 2022 7:43 pm
by Henry K. Lee
Clean. clean, and more cleaning! hand sanding inside, double wipe with acetone, then spray two heavy coats of Gyptal with acetone as a reducer. Never had a peel. Don't forget oil injection to the front timing gears.
Starting the open driveshaft system using a conventional Model T rear end with mechanical brakes.
Posted: Wed Feb 16, 2022 8:34 pm
by Henry K. Lee
Tim, I can read your chicken scratch just as good as mine Brother!
Posted: Thu Feb 17, 2022 2:27 pm
by Les Schubert
Hank
My version of the pinion shaft for a open drive shaft.
Posted: Thu Feb 17, 2022 4:56 pm
by Henry K. Lee
Looks Great Les, Mine will be similar!!!!!
Posted: Thu Feb 17, 2022 5:02 pm
by Henry K. Lee
Will after sanding and prep.., here comes the texture and paint!
Using old flat washers to prevent texture paint (Truck Bed Liner Spray) and plug off holes. Gives a machined after casting effect plus keeps your bolts after tightening from making a mess.
Posted: Thu Feb 17, 2022 5:03 pm
by Henry K. Lee
TAH DAH!!!!!!
Posted: Thu Feb 17, 2022 6:02 pm
by Scott_Conger
....wow....
Posted: Thu Feb 17, 2022 6:27 pm
by Henry K. Lee
Coming from you Scott..., WOW back at you! Thank You!
Humbled Hank
Posted: Thu Feb 17, 2022 7:24 pm
by Ned L
Absolutely beautiful work,…… I am duly impressed!
Posted: Sat Feb 19, 2022 8:47 pm
by Henry K. Lee
Well..., Perfect fit! I be Happy! On to the rear end mods for the open drive shaft system. Have to control torque, as one of my old professors used to say.., "it is your friend in power transmitting.., but a scorn woman from hell if not kept happy and in place"!
Posted: Sun Feb 20, 2022 12:45 pm
by steve plowman
This is great work Hank, thanks for sharing 8-)
Posted: Wed Feb 23, 2022 6:46 am
by Henry K. Lee
Thank You Steve! Here's more.
Going a little different from Les's mod. His is great, no doubt. I want to hold tight as I believe the weak link is in the casting of thin material in the housings, from torque tube/radius rod absorption to a "torque wing" retainer and back truss (holding closer to the source with a strong arm).
Using tubes and old flat washers will save you time in clean up from weld spatter, coming in hot on the welds.
Posted: Wed Feb 23, 2022 6:58 am
by Henry K. Lee
Now that the non accessible area is cleaned up, on to the next section. Welds are built up as I will shape into a casted effect of webs when finished. Looks like a shop class project went bad! LOL!
Bending plate steel 1/4" is made easy if you have a shop press, drill press V block, small piece of steel!
You will see why this support becomes important in my design later, catching/retaining torque. If there is a failure, in theory, no damage to the internal components (Safety Break Away)! Using a still available Winters Quick Change yoke modified with mild steel square keyways with a retaining nut. That front snout has two back to back roller bearings in front of a Fun Project adjustable preload pinion bearing. Stayed tune to this channel for more fun with Dr Frank N. Stein, aka..., Humbled Hank.
Pretty stuff coming soon!
Posted: Wed Feb 23, 2022 9:16 pm
by Henry K. Lee
A good day in the playhouse. Machined and broached the yoke, machined polyurethane to fit behind the yoke as a harmonic silencer (straight cut gears love to resonate noise causing deep harmonics, creating metal fatigue). Grinding down the welds, etc.
by Henry K. Lee
Posted: Wed Feb 23, 2022 9:55 pm
by Les Schubert
Some very interesting stuff!
Posted: Thu Feb 24, 2022 8:00 am
by Tim Rogers
Hank- you're awful brave to post some many pictures of such shoddy work! :D
Posted: Thu Feb 24, 2022 9:56 am
by Henry K. Lee
It will improve Tim I promise! I had to put the pixies in a time out! Thanks Man! LOL
Hank
Posted: Thu Feb 24, 2022 11:19 am
by Dallas Landers
You sure are good with that file and hand drill Hank! :D is that an entire roll of red tape?😂
Posted: Thu Feb 24, 2022 11:37 am
by Henry K. Lee
Dallas you better quit giving away my master craftsman secrets..., dim dar be ah fighting' words mister! LOL
OK..., Now you can get a better picture how this will work! Front torque arm/truss with a rear truss! They will tie into the rear link supports to be determined later.
Posted: Thu Feb 24, 2022 7:10 pm
by Les Schubert
A very interesting approach. Thank you for the posting
Posted: Sun Feb 27, 2022 6:10 pm
by Henry K. Lee
Another long productive day!!!!!!
Posted: Mon Feb 28, 2022 5:09 pm
by Les Schubert
Interesting approach. Looking forward to more
Posted: Sat Apr 09, 2022 9:02 am
by RVA23T
There should be more to this by now. Are you slacking off? Sabine and I were not there that long and I have not been calling you that much!! :D
Posted: Sat Apr 09, 2022 10:04 am
by Henry K. Lee
Other Priorities as the Grand God Children from England are planning on coming over! Plus Honey-Do's!
Hank
Posted: Sat Apr 09, 2022 1:01 pm
by RVA23T
Same problem, New Kitchen cabinets showed up and I was forced to stop on Scarlotte O'Hair but has her new trans and rear end from you installed now it just putting ALL the other pieces back together. Killing me running to the store in a normal car!
Posted: Thu Apr 21, 2022 1:19 pm
by Henry K. Lee
Well..., After a few delays, ie, my welder not big enough, brother Rick Rice tried to, not big enough, found some really good young guys in Chattanooga that did me proud! And as a bonus.., the wife went to Florida for a week! Goof off time.., I meant playtime.
The plates dialed in on the money with the crankshaft..., could not be happier than that. Had to machine a dumbing shaft for the dialing but part of the fun. ENJOY!
Hank
Posted: Thu Apr 21, 2022 1:45 pm
by Dropacent
I really enjoy seeing nice fabrication work.
Posted: Thu Apr 21, 2022 2:46 pm
by Les Schubert
Looks great!
Posted: Tue Apr 26, 2022 6:24 pm
by Henry K. Lee
Decided to press my good fairy luck on this project. Mounted the flywheel, bell housing, and starter then connect power to check flywheel run out..., within 0.0002! Holy Crap..., me happy!
Posted: Tue Apr 26, 2022 8:28 pm
by Les Schubert
Looks great.
Posted: Tue Apr 26, 2022 8:33 pm
by Dropacent
This could be a tv show!
