What have you done with your Model T in April?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Apr 02, 2019 12:02 am
I'll start it off this month. This isn't a specific car, but any Model T engine/transmission I need to haul in my Suburban. With limited overhead room I can't reach in with a hoist, and I've been using a wooden stand I have to slide in and out. Putting it mildly, that is no fun. So I made a stand that sits low enough to fit and will roll in and out.
Turning the handles forward puts the casters down so the stand will roll.
Turning the handles back lowers the stand to rest on the floor.
Bob McDaniel
First Name: Bob
Last Name: McDaniel
MTFCA Number: 28428
Re: What have you done with your Model T in April?
Post by Bob McDaniel » Tue Apr 02, 2019 12:33 am
Pulled the wheels off the 09 and replaced one rear wheel that was racked and not safe. Looks like the darn thing would be under warranty but the local Ford dealer is out of them. Glad I had a good spare. Getting it ready for summer!
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Apr 02, 2019 10:03 am
Nice work Steve - did you engineer that ?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Apr 02, 2019 10:12 am
...did you engineer that ?
I guess you could call it that. It was one of those things where you start building and make it up as you go. Mostly scrap on hand. I may have as much as $25 in it.
Last Name: Gregush
Post by Mark Gregush » Tue Apr 02, 2019 10:38 am
Sorry to say I pulled the Chevrolet over head conversion off my T. Not disappointed with the results, just don't have room or money to keep experimenting with it right now. It ran fine but with the carb setup I was using was slow. I will have the whole shebang at the Portland (Oregon) swap meet (EXPO center) this weekend.
1921 Huckster
Jugster
First Name: Bob
Last Name: Coiro
Board Member Since: 2009
Post by Jugster » Tue Apr 02, 2019 11:52 am
Nothing.
Not a blessed thing.
Still recovering from last month's spine surgery.
Jem
First Name: Jem
Last Name: Bowkett
Post by Jem » Tue Apr 02, 2019 5:06 pm
Got it out the shed and dusted off the cobwebs
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Tue Apr 02, 2019 6:58 pm
Bob, did you remind the surgeon not to forget the cotter pins?
Art Ebeling
First Name: Art
Last Name: Ebeling
MTFCA Number: 50718
Post by Art Ebeling » Tue Apr 02, 2019 8:01 pm
IMG_20190330_120344848_HDR.jpgGot it out the shed and dusted off the cobwebs
Jem, How about some more pictures? Art
Barth_Tool_Co
First Name: Jason
Last Name: Alvord
Post by Barth_Tool_Co » Tue Apr 02, 2019 9:26 pm
Cleaned up my pan to prep for straightening...
... and my number is Beechwood 4-5789
1926 Touring - "Corrina"
ericmac
First Name: Eric
Last Name: Macleod
MTFCA Number: 50125
MTFCI Number: 19464
Post by ericmac » Tue Apr 02, 2019 10:32 pm
While not my car, Mark and Phil Eyre are making steady progress on their '11 Torpedo project. They have the chassis and engine pretty well licked and the body is now blue. The long process of pin striping began today.
Eyre Torpedo stripe
Eyre Torpedo stripe
1913 Touring
1926 Fordor
1926 Touring
Nash, Franklin, Lincoln and Buick owner emeritus
Jeff Perkins
First Name: Jeff
Last Name: Perkins
MTFCA Number: 10642
MTFCI Number: 17799
Post by Jeff Perkins » Tue Apr 02, 2019 10:40 pm
Just bought this one and brought it home. It was sitting in a home garage near me for 30 years. Needs a good cleanup and then we will try to get it to run. Should be fun!
1913 Model T Runabout, 1919 Model T Touring, 1930 Model A Tudor, 1991 Mazda Miata
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Apr 02, 2019 11:22 pm
Shouldn't I have a valve on my carburetor to shut off the gas? No. It looks modern, and/or it's so stiff you practically have to use a wrench to turn it. After seeing a setup like this on a TT a few years ago, I made one for my 1915 runabout, and I just made another for my 1923 touring and installed it this morning. You can turn the sediment bulb valve from beside the car. No need to crawl underneath.
Two running board bolts hold a length of angle iron, which holds a rod attached to the sediment bulb valve. When the handle is down...
...the valve is closed. A short piece of tubing swivels on the end of the rod, fits over the valve handle, and is held on by a small hose clamp.
When the handle is turned up...
...the valve is open.
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Post by ivaldes1 » Wed Apr 03, 2019 12:33 am
I like it Steve, but with bumps and travel might the handle work its way down and shut the gas off? Needs some sort of say zip tie loop to go around the end of the handle and keep it from sagging down and thus closing the gas?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed Apr 03, 2019 12:54 am
This one seems stiff enough to stay put. But if it doesn't I'll add a spring catch like I did on the runabout.
VowellArt
First Name: Martynn
Last Name: Vowell
MTFCA Number: 9908
Board Member Since: 2012
Post by VowellArt » Wed Apr 03, 2019 2:07 am
I washed my car...isn't much I know, tomorrow I'm going to dismantle my Rockies and replace some washers with smaller ones, to see it that makes any difference in their performance.
Fun never quits!
CDHing
Last Name: Chan
MTFCA Number: 50211
Post by CDHing » Wed Apr 03, 2019 5:52 am
Currently, I'm slowly disassembling the Roadster seat assembly I bought at last January's Turlock Swap Meet. I believe the body section had been all original with remnants of original upholstery. It's really been a learning experience for me because I'm learning details of 1920 Roadster construction I didn't know before. This seat assembly appears to be from the time just after the switch to the oval gas tank and so the wood structure is different than what's shown on the Mel Miller drawings I'm using to reconstruct my car. The tool tray behind the tank is narrower to allow space for the wider oval tank. I'll have to convert my current pieced together body from round tank to oval tank to make it more appropriately like the 1921 which it should be. I also learned that the wooden strip going around the top edge of the seat is actually three sections reinforced with a sheet metal covering (3 sections of sheet metal reinforcement) along the back. I thought it was suppose to be a continuous steam bent 3/4 inch wood molding to nail upholstery to. It makes sense to have the sheet metal reinforcement because of the strain of the driver and passenger leaning back against the seat would need more resistance than just the 3/4 inch wood strip. Also I didn't know about the cardstock the factory used on the arm rest areas to smooth out the transitional step up caused by the use of the metal end caps. Great Model T construction fun and lots of tedious work ahead for me this April. Also this month I'm waiting on Lang's for my back ordered piston rings. I sent my engine out for machine work in February and am held up waiting for rings to come in.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed Apr 03, 2019 10:05 am
...I'm waiting on Lang's for my back ordered piston rings.
There are lots of Model T parts dealers. Maybe somebody else has them in stock.
Phillip
First Name: Phillip
Last Name: Lee
MTFCA Number: 50230
Post by Phillip » Wed Apr 03, 2019 10:09 am
Got the wood transmissions bands installed.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Apr 03, 2019 11:48 am
On my 24 touring I found, if I lift the passenger side of the floorboard up, I can easily reach the fuel shutoff.
No need to remove the mat or anything. ;)
ericmac
First Name: Eric
Last Name: Macleod
MTFCA Number: 50125
MTFCI Number: 19464
Post by ericmac » Wed Apr 03, 2019 1:21 pm
The Eyre T Torpedo looks like a car today.
Body on chassis
Body on chassis
1913 Touring
1926 Fordor
1926 Touring
MTFCA Number: 1219
Post by Rich Eagle » Wed Apr 03, 2019 1:29 pm
My gosh Eric, that looks fantastic!
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Wed Apr 03, 2019 1:47 pm
Does covering the car so it doesn't get overspray while painting something else count as doing something on my T ?
Dick
ericmac
First Name: Eric
Last Name: Macleod
MTFCA Number: 50125
MTFCI Number: 19464
Post by ericmac » Wed Apr 03, 2019 10:44 pm
I have been following along with the progress on this car for 20 years. You would not believe how good it is in person.
1913 Touring
1926 Fordor
1926 Touring
AndreFordT
First Name: Andre
Last Name: Valkenaers
MTFCA Number: 23792
MTFCI Number: 19330
Post by AndreFordT » Thu Apr 04, 2019 2:11 am
By this way I want to encourage Jugster.
I was there nine years ago but one level more, I was 54 .
It took me about 6 months to take up about a normal live again.
The job I did, heavy mechanic on harvest machines, I had to leave and went to the electronic of these machines.
I am a scuba diver on the holydays and doing this since 1974 and still doing it. I just adapt the way to do it.
Pain will never go away but it is different, and you can live with it. Nerve pain is gone only muscle stays. I don't take pain killers, only heat, stay on the move and twice a week back exercises for one hour.
At this time my only problem is COLD on my back. When the bolts get cold all your spine get cold and that give pain I can't stand. The only way for me to get rid of it is a HOT bath.
Whatever you do, LISTEN to your body !!!!!! Don't over take it but stay on the move.
Andre
Belgium
CDHing
Last Name: Chan
MTFCA Number: 50211
Post by CDHing » Thu Apr 04, 2019 6:32 am
I hope I don't come off seeming insensitive to Jugster's health situation with my posting following up after Andre's comments. Part of my motivation to get my Roadster moving along in it's re-construction is that I was recovering from an illness from late last year and as like many others on the forum I'm not getting any younger myself, but to respond to Steve's comment that there're other vendors for me to get my piston rings from, I wanted to say that Lang's was not my first choice because of their distance from California. Back in February I ordered pistons and rings from Snyder's Antique Auto Parts. They weren't able to give me a clear idea of when I could expect the rings in on a back order so, given the positive reputation of Lang's on this forum, I decided to cancel my ring order from Snyders and go with Lang's. The other vendors I checked out had websites that were not clear to me which ring sets they were offering because there are a variety of piston ring types and sizes out there covering the cast iron pistons, high domed aluminum and the non domed aluminum ones like the pistons I actually received from Snyder's. Given Lang's reputation and their extensive offering of in depth Model T parts I felt it was worth a try even though in February at the time of my ring order with them I had a magneto coil assembly on back order with them since December. At one point Lang's reassured me that it was only going to be another week, then more weeks passed. I'm at the point of rationalizing the benefits of not having my engine under foot while I'm disassembling and re-doing the bodywork on my Roadster. I spoke to a club mate of mine at the last MTFCA chapter meeting I attended in Santa Clara and he said he had had a similar back order experience with Lang's and he felt that Lang's isn't as it use to be, suggesting better past experiences. I continued to wait. Then last week my magneto coils assembly arrived and so I'm hoping maybe the rings'll make it in soon too. Lang's does have terrific telephone customer service and was sympathetic when I spoke with them a few days ago.
So Steve, that's my story for why I'm not looking to another vendor.
Just to be clear I don't mean to sound like there's anything unusually wrong with either Snyder's Antique s or Lang's. I appreciate what they offer to the Model T hobby in terms of access to replacement parts. I'm certain any of the other vendors could likewise experience delays from their suppliers too.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Thu Apr 04, 2019 9:30 am
Lubed the hand brake and cross shaft.
Greased the u-joint and tube.
Drove to the gas station and put $20 in the tank.
Came home and talked my wife into a ride. We went through a small neighborhood nearby with a few new and a few refurbished homes. Lots of trees to help block the wind that made it a little chilly. She commented on how smooth the car is running !! :D
Model T Mark
Last Name: Eyre
Post by Model T Mark » Thu Apr 04, 2019 10:22 am
Eric is correct on the 11 torpedo in the above post it has been apart since 1987. We took it apart to store it when I was 17. Next year I’ll be 50 and it was time to get it done. Life certainly gets in the way of the hobby sometimes. I’m not too computer savvy so Eric has been posting pictures as I get things done. Our hope is to have it completed for next year. It’s a closed valve twelve river rear end car. It was a pretty complete car and we did purchase repo fender and hood on it. I wish now I would have fixed the originals.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Thu Apr 04, 2019 10:26 am
I should mention, if you try to shut the fuel off this way.
Don't burn your arm on the exhaust pipe :shock:
I haven't yet... :)
Ed Fuller
First Name: Ed
Last Name: Fuller
Post by Ed Fuller » Thu Apr 04, 2019 8:41 pm
Took the pickup out for a 15 mile ride to blow the dust off from the winter.
Jem
First Name: Jem
Last Name: Bowkett
Post by Jem » Fri Apr 05, 2019 11:20 am
Art asked for more photos of my 09, here's a link to a 2018 post
http://www.mtfca.com/discus/messages/82 ... 1532436906
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Fri Apr 05, 2019 3:50 pm
Got my locking steering wheel off and lubed the gears. I think by tightening the spider screws, the pesky rattle should be gone !! :D
I also fixed the wire end for my dash light, and it works ! 8-)
Loftbed
First Name: Rod
Last Name: Letcher
MTFCA Number: 32097
Post by Loftbed » Fri Apr 05, 2019 4:13 pm
These are what came on the car.
Changed the E&J 1915 sidelights to correct 1913 sidelights and then converted the 13's to LED lights.
These are the new lED lights I got on Amazon<br />https://www.amazon.com/gp/product/B07DD772MJ/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&amp;psc=1  <br />Very bright
https://www.amazon.com/gp/product/B07DD772MJ/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Very bright
New lights all wired up.
Installed into the new light. It only took a few washers to make them fit.
13 Model T Speedster http://www.customfurniture.net/13data/
38 MG TA
57 Ford Thunderbird
1952 Jaguar XK120s FHC
1928 Buick 24 "Sport Roadster"
Loftbed
First Name: Rod
Last Name: Letcher
MTFCA Number: 32097
Post by Loftbed » Fri Apr 05, 2019 4:25 pm
The 13 Modern Speedster had turn signals installed when I got it, however the switch was below the dash in front of the passenger - very unhandy and also dangerous. I have now moved it to the seat riser under the seat and to the right of the driver a skosh, now it's easily activated with my right hand and I don't have to get all contorted as before.
Bracket I fabricated to mount the TS toggle. it gets attached to the seat riser.
38 MG TA
57 Ford Thunderbird
DLodge
First Name: Dick
Last Name: Lodge
MTFCA Number: 19659
Post by DLodge » Fri Apr 05, 2019 5:14 pm
Jem now has the cleanest cobwebs in all of Lincolnshire.... :D
ericmac
First Name: Eric
Last Name: Macleod
MTFCA Number: 50125
MTFCI Number: 19464
Post by ericmac » Fri Apr 05, 2019 10:52 pm
Here is more work on the Eyre Torpedo. All four fenders are on it and the process of buffing out the paint is well underway.
1913 Touring
1926 Fordor
1926 Touring
jagiven
First Name: Jason
Last Name: Given
Post by jagiven » Fri Apr 05, 2019 11:02 pm
Rebuilt two wheels. Spokes are finished with boiled linseed oil and turpentine. Just have to finish painting the iron components.
Tbz4u
Last Name: Weitzel
MTFCA Number: 22631
Post by Tbz4u » Fri Apr 05, 2019 11:44 pm
Ok i did take the1909 out for a ride! Unbelieveable in between Storms yea right been raining for days here . Anyway. Had problems with the coils and i new that rv Anderson had done these in 2002 well anyways i called him after numerous times tries because storms back east were bad. i got ahold id him told him he had done these he said send these to me, there under warranty. What. I insist i ll send to you and ill pay you, he said ok if its do to wear he will charge! WHO the hell warrantys something you never paid for right . Well he did i paid the shipping There and rebursed him for ride back on shipping all within 9 days id like to give him an applaud . R V. ANDERSON YOU GOT MY BUSSINESS I SEE YOUR IN THUS CAUSE YOU LOVE IT THANKS AND COILS WORK Great just ran the 1909
Tbz4u
Last Name: Weitzel
MTFCA Number: 22631
Post by Tbz4u » Fri Apr 05, 2019 11:46 pm
Sorry heres picture
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Sat Apr 06, 2019 1:18 pm
Installed outside oil line on the TT and the wire harness from Dave. Working on a front wheel to get it ready for paint. New tires arrived this week.
JRSpada4
First Name: Jim
Last Name: Spadafore
MTFCA Number: 49891
Post by JRSpada4 » Sat Apr 06, 2019 8:21 pm
I started early this morning doing my annual maintenance. Cleaned the timer, oil change, greased all the cups, etc. I finished up early afternoon and was able to finally get out for a little drive around town. I've been chomping at the bit to get out this year, but the weather hasn't been cooperative until this weekend.
Bob McDaniel
First Name: Bob
Last Name: McDaniel
MTFCA Number: 28428
Post by Bob McDaniel » Sat Apr 06, 2019 11:08 pm
One step forward, two steps back. Been working on the 09 the last couple days to get ready to drive it all weekend. Got the toe in set and packed the front wheel bearings, removed the worthless oil sight gage from the side of the pan which stopped an oil leak from the vent hole in the top of it. You can not see the oil in the window under a dark car with dark oil and a black oil pan anyway. Fixed a few small items and reset the coils on the HCCT my wife found for me and then set up the spare coils that came with the car. Most were marked .8 amps 2013 but only 1 was still at .8 and the rest were all over the place and a couple were 1.3 and 1.4. I set them all at .8 and now the car idles all the way down and is smoother. After all this I noticed fewer free starts and thought maybe I need to play with the coils more but after a long day of driving we stopped for drinks and when I shut it off the switch felt loose and then would not work. After pulling it apart in the parking lot I found all the screws were loose inside and the switch had come apart inside. I fixed that and we decided to head for home but stopped by the house of someone my wife works with to give him a ride. The car was now starting much better and free starts were back so we felt it was ready to drive till I made a sudden stop for a light and found out the brakes worked better than most T's I have driven. Then the problems came. At the next light I hit the brakes and nothing happened! Lucky for me I had fixed the rear brakes the other day when I replaced the bad wheel and found a spring had come off after someone put lined brake shoes on the car so I pulled the leaver and stopped just over the white line with my front wheels. I was able to take him home with just the rear brakes but when I got home and pulled the cover to see what happened I noticed the Kevlar bands I was told the car had were cotton! Looks like I will be putting new Kevlar bands in before we can drive it again. Glad I found this before the tour in June. We put around 50 miles on the car and it would have been a long walk. Shake down runs are so much fun!
John E. Guitar
Last Name: Guitar
Post by John E. Guitar » Sun Apr 07, 2019 3:55 am
I crossed the Blue Mountains in my 26 Tourer with the usual suspects.
260km round trip for me. It seemed to run ok although compression is currently 28, 32, 39, 32 psi.
jagiven
First Name: Jason
Last Name: Given
Post by jagiven » Sun Apr 07, 2019 5:34 pm
Went to paint the hubs their final coat of paint.
Front hub, both halves, must have had some type of contamination on them. Blistered almost immediately. Now I get to strip it, and start over. Funny thing, the rear hub, was done at the same time, sat right next to it during, and no issues with it. Both used the same paint, primer, handled exactly the same. Oh well, a little more work.
Doug Keppler
First Name: Douglas
Last Name: Keppler
MTFCA Number: 49716
Post by Doug Keppler » Sun Apr 07, 2019 5:41 pm
1924 Touring car
There's No Substitute for Proper Lubrication
Doug Keppler
First Name: Douglas
Last Name: Keppler
MTFCA Number: 49716
Post by Doug Keppler » Sun Apr 07, 2019 5:42 pm
My smart phone must be dumb it posts pictures upside down and sideways but if you click on them there right side up
1924 Touring car
George Andreasen
Last Name: Andreasen
Post by George Andreasen » Sun Apr 07, 2019 7:52 pm
I'm nearing the end of my struggles gapping my magneto magnets. Every time I mounted the flywheel my dial indicator showed a horrible .013" wobble on the non magnet side, so I pulled it apart and checked everything. All good. I finally mounted the flywheel on a mandrel in the lathe and discovered that Henry could care less about running true on the BACK side where I was measuring when it was on the engine! The face with the magnets runs within .003" or so. Good enough......I'm tired!
davidheavner
First Name: David
Last Name: Heavner
MTFCA Number: 31779
Post by davidheavner » Sun Apr 07, 2019 9:28 pm
I replaced the petcock to the sediment bowl today using Easy Turn. So far so good. No leaks.
davidheavner
First Name: David
Last Name: Heavner
MTFCA Number: 31779
Post by davidheavner » Sun Apr 07, 2019 9:38 pm
Oops. Should have said EZ Turn.
Daniel828
First Name: Daniel
Last Name: Brennan
Post by Daniel828 » Mon Apr 08, 2019 4:49 pm
Ive gotten my speedster on the ground this just today.
Still lots of work to do but getting closer
ericmac
First Name: Eric
Last Name: Macleod
MTFCA Number: 50125
MTFCI Number: 19464
Post by ericmac » Thu Apr 11, 2019 10:50 pm
Who would think something so small could cause so much trouble? In any case I am coming back the other way on this job.
Nail in 26 tire
Nail in 26 tire
1913 Touring
1926 Fordor
1926 Touring
Bob McDaniel
First Name: Bob
Last Name: McDaniel
MTFCA Number: 28428
Post by Bob McDaniel » Thu Apr 11, 2019 11:10 pm
Finished putting in the new Kevlar bands tonight. Not a fun job with a bad back!
ericmac
First Name: Eric
Last Name: Macleod
MTFCA Number: 50125
MTFCI Number: 19464
Post by ericmac » Fri Apr 12, 2019 6:21 am
The hood slipped right on the Eyre Torpedo. It's only two inches longer than standard but it looks lick much more than that. And oh what a wonderful optical illusion it is!
Eyre hood
Eyre hood
1913 Touring
1926 Fordor
1926 Touring
Tiger Tim
Last Name: Eckensviller
Post by Tiger Tim » Fri Apr 12, 2019 7:37 pm
All I didn’t this month was chip all of the ice away from my garage door and go for a short drive to see what needed to be addressed/adjusted. The short answer seems to be ‘everything.’
I’ll be a busy T mechanic in May...
Graybeard77
First Name: Clyde
Last Name: Gibson
MTFCA Number: 32266
Post by Graybeard77 » Fri Apr 12, 2019 8:55 pm
I put the motor back in "Lulabel". My outdoor shop is going to leak tommorow so won't get it running until next week. Looking forward to driving the for-door. The new Z head ought to help her climb the hills better.
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Sat Apr 13, 2019 12:52 am
Removed my 100 year old top
Ralph F
First Name: Ralph
Last Name: Fitz-Gerald
Post by Ralph F » Sat Apr 13, 2019 7:11 am
Now that mud season is well under way here in Vermont, it time to put some water in the radiator, fix the driver's cushion, and put some air in the tires. If doesn't rain Sunday afternoon my daughter and I are off to the local sugar house for some sugar on snow.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sat Apr 13, 2019 4:50 pm
I finished something today! A couple of somethings, in fact. Accessories to enhance the driving experience.
The first project was a pair of extensions that will allow me to back up without getting my big feet tangled in the pedals. Nobody will ever accuse me of being a skilled welder, but I don't think these will come apart.
This one is for the touring and the other will go in the runabout. I could have bought prettier ones for $60+, but these are from scraps and materials on hand for no cash expenditure.
The other improvement is this mirror for the touring. The cash spent on this was $2 for a new mirror, as the old one was pretty bad.
I found the original mounting hardware in my parts room, but there was no clamp to hold it on the window frame. So I made one from a piece of 1" conduit.
This should keep me informed if anybody is sneaking up on me from behind.
PDGx
First Name: Paul
Last Name: Grohsmeyer
MTFCA Number: 27359
Post by PDGx » Sat Apr 13, 2019 8:34 pm
Took the ole boy to the 2019 Florida Tow Show in Orlando.
Was parked next to a 2018 Peterbilt/ Jerr-Dan 85 ton Rotator. (2 drive axles, 1 bogie, and 2 steer axles).
We’ve come a long way in 100 years !
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
Can’t, ain’t Possible
‘17 TT / Holmes Wrecker
‘22 Mack AC
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sat Apr 13, 2019 9:58 pm
Found a fair to middling tire that will do for short trips. Not much tread, but not as cracked. The right rear, I discovered, has a split started by the bead, about 3" long !! :shock: Looking at some takeoffs Tuesday that hopefully will get me through the summer.
Went for a little spin and put a coat of wax on to get the water spots off.
Bill, another local T nut, stopped by with his 24 RPU. Beautiful car, he couldn't say enough about Joe Bell doing his engine, sounded great. :D
Like a moron, I didn't take a picture :roll:
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Sat Apr 13, 2019 11:23 pm
Welded (dropped metal balls) six small pieces to the right A-pillar which is the final body piece that rests on the sub-frame. It's only been several years to get to this point, working off photos without dimensions. Finally, was able to test fit the front and back body halves of the coupe together to see what needs to be fixed. Can't replace the skin yet as it would get in the way of welding things in place. I learned that there was no way for Ford to assemble (rivet) the body frame to the sub-frame at the factory with the skin in place on the improved models. I dunno, maybe he did anyway.
Vern (Vieux Carre)
WayneJ
Last Name: Jorgensen
MTFCA Number: 31697
MTFCI Number: 23399
Post by WayneJ » Sun Apr 14, 2019 11:28 am
I installed my speedometer in my 1915 Runabout:
Wayne Jorgensen, Batavia, IL
JEC
Last Name: Cox
Post by JEC » Sun Apr 14, 2019 11:41 am
My wife goes to a quilting romp with her Missouri girl friends every year in April.
This year I hauled my 25 pickup back and my friend Wayne Ringgenberg helped me put the seat back upholstery and top on.
He knowing what he was doing as opposed to me did most of the work.
We only had three days to complete the job and we are both over 80 years of age so I came home with some minor unskilled jobs left
Post by Scott_Conger » Sun Apr 14, 2019 12:19 pm
Looking good, John!
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Sun Apr 14, 2019 8:23 pm
I'm kind of ashamed to admit it, but after letting my car sit for too many years because the issues seemed (at the time) overwhelming, I got off my butt and got her running again. She still has bearing issues, but she runs. Someone a year ago said they had a '15 motor that was fresh and new... that they'd be willing to sell, but we lost touch (darn!!!).
So that's what I've done... so far. Still need to get the mains and rods done, maybe do a whole KRW on her, but for now... she runs.
Daniel828
First Name: Daniel
Last Name: Brennan
Post by Daniel828 » Sun Apr 14, 2019 11:20 pm
I rolled my project out of the garage the other day for the first time ever. This car was made from parts acquired from friends and visits to Hershey
It was going to be a speedster but I’m changing direction and I’m going to build a depot hack body for it
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Mon Apr 15, 2019 1:00 am
I finished my 14 coil box good enough that I can put it back on. I need to finish the top and get the latches plated, I was thinking about getting a Caswell kit because the bolts that hold it on, I know what they look like and can make some but I think they should be brass plated too along with other odds and ends. My 14 box was stressed and rusted and the corners split. I bent a piece of round rod and welded in the corners in the bead for strength then filed them flat. I clamped aluminum angle inside and welded up the corners and patched a couple holes. I’ve had the box from my 21 on my 14 so I put it back today. Haven’t started it in 6 or 8 months but it started right up.
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Mon Apr 15, 2019 10:36 am
Ran the 15 motor a few more times.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Tue Apr 16, 2019 7:03 pm
Went to Bill's and got a couple pics of his 2 Ts.
From there to a lady close by and got a couple decent used Firestones, a USA tube and a Ruckstell shifter.
Ordered a couple new tubes, but found another USA tube in my old tire and took a chance...holding so far !! Tomorrow I may try the other tube, I have a bare rim.
The old tire was a little unnerving ! :shock:
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Apr 16, 2019 8:14 pm
Dave ! You mean you had to go to someones garage to find T parts? :shock:
Looking at their cars and searching their spare parts for what you need is1/2 the fun.
JEC
Last Name: Cox
Post by JEC » Tue Apr 16, 2019 9:06 pm
I am replacing my rotten tires and while I have them off am refinishing the wheels.
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Sat Apr 20, 2019 3:58 pm
Slot screw
Slot screw
The Bendix cover screws were shot like everything else when we got the car and I tried to replace them with stainless but the screws were too tight. So, I tapped/re-threaded the holes to 1/4" not knowing that they were #14. That was the first mistake. Then the screws went in just fine. But as I was told on this forum, Philips head screws did not exist then (mistake #2). After looking locally for slotted screws and not finding them, we bought some stainless hex heads, mounted each screw in a drill (my wife operating the drill) and me operating the grinder at the same time. After rounding the screws, we used a cut off wheel to create the slot. I'm sure many of you have done this many times. For those who need to know, 5/8" bolt length seems good.
Vern (Vieux Carre)
JAMES P
Last Name: Pringle
Post by JAMES P » Sat Apr 20, 2019 5:01 pm
Last week we travelled down to North East England and had 4 excellent days at Beamish ( The living museum ) Great North Steam Fair. All vehicles pre 1930 and a great selection of T's, including my friends ton truck and my 13
Link to youtube video https://www.youtube.com/watch?v=2sc92N_lmY0
ericmac
First Name: Eric
Last Name: Macleod
MTFCA Number: 50125
MTFCI Number: 19464
Post by ericmac » Sun Apr 21, 2019 7:31 am
The Eyre Torpedo continues to make steady progress. The side lamps and top bows are now in place. Meanwhile Gord Koll finished my replacement dadh for my '13 Touring. It's a work of art.
Eyre Torpedo top bows
1913 Touring
1926 Fordor
1926 Touring
ericmac
First Name: Eric
Last Name: Macleod
MTFCA Number: 50125
MTFCI Number: 19464
Post by ericmac » Sun Apr 21, 2019 7:35 am
My 13 Dash. Thanks Gord! I have been trying to decide if I will make it look "weathered " to match the rest of the car or factory new. Right now I am leaning towards new.
13 dash
13 dash
1913 Touring
1926 Fordor
1926 Touring
Darren J Wallace
First Name: Darren
Last Name: Wallace
Post by Darren J Wallace » Sun Apr 21, 2019 11:01 am
Painted my hubcaps for my '13
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Apr 21, 2019 11:44 am
Drove the 23 touring almost 30 miles yesterday. The engine is still pretty fresh (under 200 miles) so I keep it down to 20-25 mph.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Sun Apr 21, 2019 2:48 pm
I exhibited fifty seven 11x14” prints of my ‘23 model T in a one man show in Ra’anana, Israel. Here is a view of one of the three walls of the installation. Most of the people attending the opening had never seen a model T Ford. So I spread the gospel according to T. Upon returning home after a 12 hour flight I immediately hopped into the T drove it for about two hours.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sun Apr 21, 2019 5:27 pm
Ain't nothing special really--just started putting the white ribbed tires on the '13. Rear done now...maybe Monday or Tuesday the front and then I can take her for a spring spin!
fbergski
First Name: Philip
Last Name: Berg
Post by fbergski » Sun Apr 21, 2019 5:52 pm
Drove Isabel to Cars & Coffee yesterday, spent most of my time explaining how oil lamps work!!
1115
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sun Apr 21, 2019 9:26 pm
Had all the kids here today for Easter dinner.
Took my granddaughter for her first T ride !!
She's 14 but was all smiles, I think she put her phone down for a couple minutes ! :D
Last Name: Gregush
Post by Mark Gregush » Mon Apr 22, 2019 11:55 am
Re"The Bendix cover screws were shot like everything else when we got the car and I tried to replace them with stainless but the screws were too tight. So, I tapped/re-threaded the holes to 1/4" not knowing that they were #14."
Unless someone in the past has messed with the cover screw, they are smaller then 1/4" or #14. The thread is an interference type and the screws are closer to metric.
I decided that after all the work putting the Chevrolet overhead on my 21 that I was going to keep it. I put new rings in and took up the rods a bit. Because you are using 7/16 bolts in 1/2"+ holes it gives a lot of latitude to where the head sits so this time I installed locating pins where I wanted it to sit. The holes were a bit bigger then the pins I used but they are only there to located to install not keep it from moving later
I also decided to replace the valve springs. Took a bit of searching thru the SBi catalog but found some that were withing the ballpark. To get the compression at working height I added shims at the top, no room at the bottom. Didn't want something too strong because A the cam is not that strong and B didn't want to break the rocker arms.
I also plugged the unused rear water passage, took a little more off where the plate meets the block at the fire ring. And yes I am after coating very well with copper coat am reusing the two head gaskets.
1921 Huckster
John Codman
Last Name: Codman
Post by John Codman » Mon Apr 22, 2019 5:27 pm
I drove it yesterday. That's what it is for.
BobD
First Name: Bob
Last Name: Doris
MTFCA Number: 32538
Post by BobD » Tue Apr 23, 2019 2:35 pm
After searching for a 1926/’27 fan at Bakersfield. (The one I did find was cracked.) I ordered a new reproduction fan from Snyders. Very pleased with the quality of the reproduction fan. It is well made and looks exactly like the original. The holes lined up perfectly. It even comes black powder coated for durability. Anyone who needs an “improved” fan will not be disappointed.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Apr 23, 2019 11:03 pm
Stuck indoors on a rainy day, I installed the spare carrier on my 1923 touring and mounted a spare tire. Little by little I'm getting the car ready to make some trips.
Rob Patterson
Last Name: Patterson
Board Member Since: 2003
Post by Rob Patterson » Tue Apr 23, 2019 11:25 pm
I finished my Speedster build.
Well, finished it enough to be able to drive it, register it and put licence plates on it for the first time.
Cheers,
Rob
"When everything seems to be going against you, remember that the airplane takes off against the wind, not with it." HENRY FORD
John E. Guitar
Last Name: Guitar
Post by John E. Guitar » Wed Apr 24, 2019 2:19 am
I discovered my third conrod needs a birthday.
Colin Mavins
First Name: Colin
Last Name: Mavins
MTFCA Number: 1853
Post by Colin Mavins » Wed Apr 24, 2019 10:37 am
I am working on going faster so not working on the T but did have it out for a drive then changed the oil and filled the oilers and grease cups . Now back to the ambassador we now have the wheel well done . Cheers Colin
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Wed Apr 24, 2019 12:15 pm
Well I worked on the 8in1 bed and its ready for final paint
Then I done a compression test on the RPU and found #3 at zero. Pulled the head and decided new valves and tappets are in order
I finished the front wheels for the TT last night. Sorry I didnt take a photo, it was late.
After the wheels I started removing all the harware on the tailgate for the 8in1 to replace a couple boards so I can paint it with the bed. Whew, Im beat!
Tom Hicks
First Name: Thomas
Last Name: Hicks
MTFCA Number: 32518
Post by Tom Hicks » Wed Apr 24, 2019 3:28 pm
I drove Ellie Mae up to Home Depot and three people commented that she looked like the Beverly HIllbilly's truck. She really doesn't, but since that is my goal it really gave me a boost. Can't wait to get the bed sides on and the rocking chair in the back!
mvweaver
First Name: Matthew
Last Name: Weaver
Post by mvweaver » Wed Apr 24, 2019 9:29 pm
Well thought I had my 20 yr project sold to a fella in NJ and then the tax man hit him. So, I decided I better go ahead and get it running again. Swapped out the incorrect low radiator for a high radiator and dinged up nickel shell. Mounted the rebuilt carb I bought from Tom Strickland last year at the Marietta swap meet. Ordered a fuel shutoff valve, fuel line, packing and pack nuts from Snyder’s. Got them and got the cab laid back to put the fuel tank in. Started to mount the Ruxtell shifter but didn’t have the right hardware, so got that sorted but not mounted yet. Hope to fire it up this week for the first time in about 10yrs. Cab’s gonna need some love before I mount the bed. It’s either getting my Anthony Autorocker or the original flatbed. Here’s a few pics.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Wed Apr 24, 2019 9:52 pm
DSCN5615.JPGI am working on going faster so not working on the T but did have it out for a drive then changed the oil and filled the oilers and grease cups . Now back to the ambassador we now have the wheel well done . Cheers Colin
I think you should tell/show us more of the AMC !!
Maybe start an OT thread. :D
John Dow
Last Name: Dow
MTFCA Number: 32344
MTFCI Number: 24459
Post by John Dow » Wed Apr 24, 2019 10:45 pm
Check out my front tag.....
Tom Hicks
First Name: Thomas
Last Name: Hicks
MTFCA Number: 32518
Post by Tom Hicks » Thu Apr 25, 2019 6:54 am
I have started making Ellie Mae's bed. Hope she likes it! All of her wood is salt treated, then I put a penetrating stain on it, she is an outdoors type of girl. The outside frame is done, the actual bed won't take long. The sides are going to take a while, they have to be strong so passengers can push/pull them, but none of the stakes or rails can be straight, level, or plumb. That is where Jed's real carpentry skills will show and I think it will give the truck the Beverly Hills look I am after.
Tom Hicks
First Name: Thomas
Last Name: Hicks
MTFCA Number: 32518
Post by Tom Hicks » Fri Apr 26, 2019 8:52 am
I was busy last night! Next I have to make a removable gate for the back. Passenger access to the rear is across where the passenger seat should be.
I hope I am making Jed proud!
John Codman
Last Name: Codman
Post by John Codman » Fri Apr 26, 2019 10:43 am
I haven't done a dang thing to it, but I did take it for a ride last Sunday. I discovered a guy with an ultimate man-cave, and another who is a contractor who I may hire to do some work on our house. The T does attract attention. The two guys that I met are into British sports car racing, and were fascinated by the T's wooden spoked wheels.
John Dow
Last Name: Dow
MTFCA Number: 32344
MTFCI Number: 24459
Post by John Dow » Fri Apr 26, 2019 12:00 pm
I replaced my Anderson timer with a TW. Wow what a difference!!!
Last Name: Gregush
Post by Mark Gregush » Fri Apr 26, 2019 12:09 pm
Taking Nelly-Bell the Raloo Rocket on it's first drive after getting new rings and different carb. Put a Stromberg OS-1 on. Photos later. When I get to the shop will re-adjust the valves, they need to be set at running temp. Also need to dial in the carb, right now it is loading up at a low idle. Too fast an idle, hard to get the Warford shifted at stand still even with using the transmission brake to slow the gears down. (might need to adjust the brake band too!)
1921 Huckster
Last Name: Gregush
Post by Mark Gregush » Fri Apr 26, 2019 8:13 pm
Did some bending on foot feed and added a different return spring. Adjusted the valves. Here is my Stromberg OS-1. Still needs a little dialing in but runs better still some popping if I open too fast.
1921 Huckster
D.Yoder
First Name: DEAN
Last Name: YODER
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Sat Apr 27, 2019 7:30 pm
Made seat covers for the 100 year old seats.
Covered the 100 year old holy material
