Removing headlight reflector
Posted: Wed Jan 26, 2022 3:01 pm
How do you remove reflector on a 24 ? The parts list shows a wire spring. The reflector will push in and looks like slots could be turned line up with tabs in bucket.
Also this inexpensive strap wrench that I had worked good to remove rim.
https://aboloxtools.com/Williams-40221? ... %20%2411.1
John
John
