Magnet Charging
Posted: Wed Jan 26, 2022 4:30 pm
The following is a sharing of my current methods for a best magnet recharge method. I strive for the best possible repair/restoration methods available. I am open minded to any better way.
There are 2 recharging methods. In car & disassembled motor. Using a large DC arc welder has given a 25-30V mag output in car. Best output I know of.
A field coil can be similarly used laying on a disassembled transmission flywheel's magnets. I would expect as good or better output with direct magnet/field coil contact.
BUT if apart, why? Go the extra mile & do the magnets OFF individually.(to insure all magnets are good. crack free & otherwise)
Remove & clean the magnets. Hit them looking for them to show a break. Additionally hang via a string & ring test. You should hear a continuous long ring like a tuning fork. If you get no long ring replace it.
Get out a compass & mark each with its polarity. I also measure & mark the magnets thickness on the ends to make setting the heights when assembling easier. Note the magnet box has an old ring gear as a "keeper" built in. The recharging coils fit over each magnet. Polarity observed. Power source was a 12V battery from my truck. Running @ 14V. I have used a 12V battery & 100 amp battery charger. Striking once some times didnt give a maximum charge. 4-5 quick hits is the norm. Maximum magnet charge seems to be achieved. Saturation.
This method I used on my '14. It puts out 35V @ speed. Starts easily on 1/4 crank.
This was night 1.
Day 2
I am wondering about the tool that has the coils fixed to the cores & is walked around a flywheel or individual magnets that magnetize by contacting magnet ends.
Is it as effective? Lets test! Night 2
Using a magnet as a fixed core in my 2 coils, I placed another magnet against the ends for re magnetizing. Simulating that other type charging unit.
The result was an inferior charge. Would not hold the 4# sledge. Tried several recharges, but never got enough charge. In case the problem is the magnet, I placed the new magnet in the coils as with the other magnets for charge & got a good full charge.
My conclusion: the charging tool that contacts magnet ends does an inferior job. In addition. 1 of the magnets in the pile didnt pass the ring test. Thud. I beat on it & it wouldnt break. I noticed it was rougher & thinner like not enough material when it was rolled out. Gave it a charge. It would not take a "full" charge. It would not hold the 4# sledge & gave a similar meter read as #3 magnet above. Defective. It will not be used.
This was night 1.
Day 2
