1911 fire wall and fire wall support
Posted: Fri Jan 28, 2022 1:27 pm
by AndreFordT
Hi all,
I am working on a 1911 Model T Torpedo.
Last week I ordered the right fire wall and finished the clear coat job.
I have questions about the fire wall supports. Are they different as the 1913 support?
In the fire wall, on the car they are three bolt to attach the support on the fire wall.
On the fire wall, I ordered, there are only two holes to fix the fire wall. The drawing shows the same.
Can some one post some good photos of the 1911 torpedo fire wall and the way it is attached to the body and the frame inside and outside?
Andre
Belgium
Re: 1911 fire wall and fire wall support
Posted: Fri Jan 28, 2022 2:59 pm
by pete eastwood
the 1911 " torpedo " has unique frame to firewall mounting brackets .
It has two mounting holes to the dash & it is offset 2 inches to the rear where it mounts to the frame,
as the torpedo hood is 2 inches longer .
Posted: Fri Jan 28, 2022 3:05 pm
by pete eastwood
these are Torpedo brackets
Posted: Fri Jan 28, 2022 6:24 pm
by AndreFordT
Thanks Pete,
Do you have measurments for these brackets?
Andre
Belgium
Posted: Fri Jan 28, 2022 7:24 pm
by ahovey
Sorry for the wacky orientation but this should help. These are the dimensions from a likely repro bracket I have. Email me if you need anything, good luck!
Posted: Fri Jan 28, 2022 11:13 pm
by Toddman
I am looking for a pair of Torpedo fire wall brackets for my 1911 open runabout. If anyone has a pair fore sale please let me know.
Many Thanks !!
Toddmanoff@gmail.com
Posted: Fri Jan 28, 2022 11:28 pm
by Toddman
Ahovey,
Thanks for posting the drawing .
Can you tell me the dimentions on the torpedo style brackets.
Vertical holes, center to center 5"
From bottom (frame side) to lower vertical hole center ?
Horizontal holes center to center ?
From bottom corner to center of first horizontal hole ?
Many thanks
Toddman
Posted: Sat Jan 29, 2022 7:59 am
by AndreFordT
I just found brackets in Chaffins Garage catalog .
3640/41T Firewall to Frame bracket set Torpedo.
Send a mail for availability of the parts.
Andre
Belgium
Posted: Sat Jan 29, 2022 8:12 am
by DickC
This may not be important and incorrect. I noticed that the firewall is drilled for the steering column bracket. I have been told that the lower hole is offset only on 1913. It looks like the firewall is drilled that way. I will not feel bad if I am corrected!!! Dick C.
Posted: Sat Jan 29, 2022 8:43 pm
by KWTownsend
Austin-
Thanks for those dimensions.
What is the dimension from the flat back side to the center of the back hole?
What is the distance between the holes?
Thanks,
Keith
