Electrical Problem (possibly newbie ignorance)
Posted: Tue Apr 02, 2019 8:35 pm
Hello all,
I am the proud new owner of a 1925 Touring modified with a distributor. Here is the problem I'm having. It will start fine with the key turned counterclockwise (batt) but just dies when switched to magneto. At the risk of stating the obvious, this suggests to me that the magneto is bad (and might have been the impetus for installing the distributor in the first place).
What I'd like to know is whether I can run the car on batt all the time, or will that create a problem? Is the battery charging?
