connecting rod pin bolts
Posted: Wed Feb 02, 2022 6:41 pm
by DonH
should the bolt holding the pin rod face the front of the piston or the rear?
Re: connecting rod pin bolts
Posted: Wed Feb 02, 2022 6:59 pm
by DonH
I think the bolt should face the cam side of the engine and instead of cotter key, wire bolt to rod.
Posted: Wed Feb 02, 2022 8:20 pm
by Kerry
Face the cam shaft, wiring the bolt to the rod has been known to come a drift and end up in the magneto, cotter pin or use a spring washer.
Posted: Wed Feb 02, 2022 8:49 pm
Faces the camshaft. the slot in the piston faces away from the cam. The cotter pin is placed in such a way that the folded end is against the rod so the bolt cannot turn.
Posted: Thu Feb 03, 2022 10:49 am
by DonH
thank you all for your help!!
