Starter Bendix Question
Posted: Thu Feb 03, 2022 7:54 am
by Plankhill
Are short nose ones earlier than the long nose ones or the other way around?
Re: Starter Bendix Question
Posted: Thu Feb 03, 2022 8:29 am
Believe the one on the left is Model A.
Posted: Thu Feb 03, 2022 8:32 am
The one on the right is correct for all. The left is a close replacement. Better then not, but not quite right. Cant speak to model A usage.
Posted: Thu Feb 03, 2022 8:45 am
by Plankhill
Not Model A Came off a Model T .
Posted: Thu Feb 03, 2022 11:00 am
My post was completely wrong and has been retracted
Posted: Thu Feb 03, 2022 11:12 am
by Kevin Pharis
Model A starter shafts are larger diameter than a T. Seems to me T is 1/2”, and A is 5/8”...
Posted: Thu Feb 03, 2022 11:38 am
by BobD
Early Model A's with the Abell starter drive had 1/2" shaft. From Oct. 1928 on, the 5/8" Bendix to end of production.
Posted: Thu Feb 03, 2022 11:42 am
Kevin and BobD
you are right and I was completely wrong. So wrong, that I revised my post to the extent that I could
Posted: Thu Feb 03, 2022 2:18 pm
The Bendix drive head for the one on the left is a bit longer than T and uses a different lock bolt depth too, still think one on left is early Model A.
Posted: Thu Feb 03, 2022 4:04 pm
by BobD
Early Model A Abell starter drive.
