Another upholstry part ??? N.O.S. strange Button w/ hole
Posted: Thu Feb 03, 2022 12:06 pm
by FATMAN
Going through some more boxes and ran across these small odd shape looks like buttons but have odd shape and hole in other side, also some odd fastners , any ideas??? Bob
Re: Another upholstry part ??? N.O.S. strange Button w/ hole
Posted: Thu Feb 03, 2022 4:02 pm
by FATMAN
Any ideas got a few boxes and appreciate the help, Bob
Posted: Thu Feb 03, 2022 4:32 pm
by DanTreace
Bob
Appears to be the fabric side of the ANZO, they likely came in many cap styles, the Ford uses a more flat like cap, but these would go with the other ANZO parts you showed. Info on this older post. There is a tool that compressed the 2 part cap together.
http://www.mtfca.com/discus/messages/50 ... 1437161088
Posted: Thu Feb 03, 2022 6:11 pm
by KWTownsend
Bob
What is the inside diameter of the female part?
What is the outside diameter of the head?
Keith
Posted: Fri Feb 04, 2022 9:54 am
by Original Smith
Those are indeed Anzo fasteners. When I restored my 1925, I went to a lot of trouble to find those, which are correct for many years of T's. I even had a special setting tool made to use.
Posted: Fri Feb 04, 2022 11:18 am
by FATMAN
5/32" i d. any idea on the funny little top shape caps ? Bob
Posted: Fri Feb 04, 2022 11:34 am
by KWTownsend
Bob,
Those are a little smaller than Anzo fasteners.
I believe they were commonly called glove fasteners.
Are the heads about 5/8"?
Posted: Fri Feb 04, 2022 11:36 am
by TRDxB2
From past thread viewtopic.php?f=2&t=8471
Who else would know :D
Posted: Fri Feb 04, 2022 11:44 am
by KWTownsend
Here are Anzo studs.
The woodscrew threaded stud was used in 1911-1912 (maybe earlier too?) top bows to attach side curtains. They used the heads that look like snaps.
The stud with the machine screw threads was used with the lift a dot fasteners.
Posted: Fri Feb 04, 2022 11:46 am
by TRDxB2
ANZO Hardware
Posted: Fri Feb 04, 2022 11:47 am
by FATMAN
19/32" across the top hat
