Flywheel dowel pins
Posted: Sun Feb 06, 2022 5:00 pm
by Don ellis
Is there a certain direction they press out like the triple gear pins?
Re: Flywheel dowel pins
Posted: Sun Feb 06, 2022 5:33 pm
by Kerry
They only come out one way, tap them out with a drift and hammer, not that tight, from the transmission side.
Posted: Sun Feb 06, 2022 5:39 pm
by Don ellis
Thanks, I started that direction but thought I would ask to be safe.
Posted: Mon Feb 07, 2022 1:39 am
by Altair
And they are pressed in from the backside. The fitted area is about .001 larger than the post. Sometimes when they have been removed some material can also be removed and you may need a larger base for a tight fit.
Posted: Mon Feb 07, 2022 2:24 am
by Kerry
I'm not sure on following you David, the dowels would tap in on the magnet side, to me that would be the front of the fly wheel as it faces the front of the engine.
