How do I balance brakes?
Posted: Fri Feb 25, 2022 6:49 am
Hello.
Last sunday I started my Lizzy first time this year. It still is sitting on four support frames, so all four wheels are a little bit above garage floor.
The engine started surprisingly easy. On 2nd try the engine started, but stalled, on 3rd try it was running smoothly.
The handbrake lever was in back position, but the left wheel was still running, while the right wheel was standing still... Then I used some more force on handbrake lever and got one more "click", then the left wheel was also standing still.
--> So the parking brake is not balanced well.
I shortened the left pulling rod by one turn of the clevis, but I didn't try again (it only can have become better, but I have no idea about how much better). Reason: Even with good ventilation of my garage the CO meter shows very quickly 600-800 ppm and I am not willing to get poisoned. Later I will do some fine tuning when my Lizzy is parked outdoors on the street.
How do you adjust brakes?
I have following brakes installed:
My idea for adjusting the parking brake is:
Pull the braking lever only to the point where I can still rotate both wheels by hands (with as much force I can apply with my hands). Then I shorten the easier turning wheel's rod by turning the clevis bit by bit until both wheels are needing almost the same force.
For A.C. Brakes it is more complicated.
There is one band brake in the engine (working on both rear wheels through the differential) and two individual brakes on the wheels. To get most efficiency I want to involve the front band brake, too. But how to find the sweet spot between this three brakes?
After re-inserting the engine (it was pulled for replacing the clutches), I set the internal brake to that point where the pedal stops 2" before the end of the related floor board slot. Then I connected the clevis of A.C. brakes to the pedal again. From my last test drive - yes, I could brake, but it was not very strong. So I am not sure if this was primarily the braking band or A.C. Brakes.
An suggestions are welcome.
Rainer
- Parking brakes (of course)
- Inner band brake (of course), with good lining.
- A.C. Brakes.
They are a little smaller than Rocky Mountain brakes and work on the outside of rear parking brake drums, having a band divided into two halves with linings. This brakes have separate pulling rods to another axle mounted closely behind the engine to the frame. This brakes are coupled to the brake pedal, so when pressing the pedal, the brake band inside the gearbox and rear AC brakes work simultaneously.
Rainer
