What have you done on your Model T in March?
Posted: Fri Mar 04, 2022 2:23 pm
by mbowen
I had the front axle and steering components from my ‘24 touring car straightened and rebushed a couple of months ago, got them cleaned up and painted a couple weeks ago, and am finally getting around to getting them reassembled. When I was reinstalling the tie rod I thought it was interesting to see how much the axle had been twisted. :shock: It was an easy job to loosen the adjustable clevis/ball-end and make the correction. The spindles appear parallel to the naked eye, but I’m going to leave the bolts finger tight until I get the axle and wheels reinstalled and check the toe-in.
Earlier this week I got all the spring components cleaned up and have started the painting process. I’m using Rustoleum Rust Reformer on all the parts except the perches, which had good paint on them before. They cleaned up nice and bright so I’m using Rustoleum self-etching zinc oxide primer on them. I’ll be topcoating the bottom surfaces of all the spring leaves except the main with EZ-Slide graphite paint, which seems to be doing it’s job on the front spring of my ‘25 express wagon. I’ll topcoat everything else with Rustoleum black satin enamel. That’s what’s on the axle, and it looks good without being too glossy.
The last job before reinstalling the axle will be cleaning up and painting the radius rod. In the meantime I have an airplane whose brakes need attention…
Re: What have you done on your Model T in March?
Posted: Fri Mar 04, 2022 2:59 pm
by Dallas Landers
Lookin good on front axle. I just went through the front axle on my TT. By the way, are those "air brakes" on your plane?😁
Posted: Fri Mar 04, 2022 3:05 pm
by Rich in Colorado
Finally finished installing the interior kit in the '22 Center Door.
Posted: Fri Mar 04, 2022 3:17 pm
by Rich Eagle
That looks fantastic. Nice work.
Rich E.
Posted: Fri Mar 04, 2022 3:39 pm
by mbowen
😂My ‘55 Cessna 170 is slow enough without air brakes. Having tailwheel geometry that causes steering input to be a mere suggestion, the brakes are more for ground steering than slowing or stopping.
Posted: Sun Mar 06, 2022 9:17 am
by Dallas Landers
Nothing but the grandkids put hundreds of miles on the TT
in my shop yesterday.
Posted: Sun Mar 06, 2022 11:39 am
by 130nav
Water pump removed, hoses and pipe installed. Just got to fill it with coolant, and hopefully starting next time.
Posted: Sun Mar 06, 2022 3:22 pm
by TWrenn
Lucky you Dallas! Glad you got out with 'em. Cute kids. I just started painting my new spoked wheels for the Fordor.
Posted: Wed Mar 09, 2022 7:29 pm
by varmint
The lip of the fender on the '26 coupe is sheet metal wrapped around about a 1/8" steel rod.
While making a patch panel which included the rod, I found that the rod was one inch too short to reach the end.
In this experiment I used stainless steel wire welding and extended it 2-1/2" (more than I needed). I suppose I was having too much fun.
I then hit it with a grinder to the correct diameter and finished rolling it into the sheet steel with a hammer and punch.
The punch is the dark grey homemade tool (not the cold chisel).
Posted: Wed Mar 09, 2022 8:27 pm
by mbowen
Getting closer to getting the front axle back under my ‘24 touring car. Today I got the spring reassembled, and hung it with new forged shackles. I still need to clean up and paint the radius rod, spring hanger, and license plate bracket. Also found out today that the tie rod bolts take larger oilers than the rest of the axle, and that I inadvertently ordered spring clamp bolts for the rear spring instead of the front. It’s always something…
Posted: Thu Mar 10, 2022 10:16 am
by Tbird
Finally got my rear fender irons casted for my delivery car project. Going from original Ford prints to 3D Modeling and 3D printing one for the metal casters to finished casting. I still need to do some finish work on them and get the holes drilled. What took the longest was finding a place willing to do them and in a small run.
Posted: Thu Mar 10, 2022 10:37 am
by Rich Eagle
Very nice Mike. Thanks for showing them.
Posted: Thu Mar 10, 2022 10:50 am
by abcarswell
Rear end going together on Clarabelle the TT. Got all the parts sourced and now just time for reassembly and painting.
Posted: Thu Mar 10, 2022 12:51 pm
by John Codman
Removed the front mat and floorboards to adjust clutch linkage. I found some sloppy linkage and ordered new from Lang's. As soon as the parts arrive I will install them and finally get the linkage properly adjusted.
Update: Ya win one once in a while! The slop was where the linkage end goes through the pedal. I envisioned having to remove the pedal and have a bushing pressed into the oversize hole for the linkage. Surprise! The wear was almost entirely on the linkage end, so all that I have to do is install the new linkage that just arrived from Lang's. Yesss!
Update: Finished installing the clutch linkage and the slop is gone! Unfortunately even with adjusting the brake/clutch lever to the max I still don't have a "free" clutch. I'm going to have to go into the transmission and do the internal adjustment. Rats!
Posted: Fri Mar 11, 2022 2:28 pm
by Corey Walker
Took my carbide generator off and restored it. It looked bad compared to the rest of the car, now the rest of the car will look bad compared to it.
Posted: Sun Mar 13, 2022 5:21 pm
by Mark Nunn
My neighbor recently opened an antique store near my home. This running board toolbox was on the porch. It's mine now. 😀
Posted: Wed Mar 16, 2022 2:44 pm
by JRSpada4
We finally got some nice weather this week, so I finally got around to installing the Ruckstell shifter and wooden steering wheel I picked up at the Marietta swap meet. The shifter replaced the one that came with the car because someone in its past cut it off Code to the floor.
Posted: Thu Mar 17, 2022 6:52 pm
by NU2theT
Replaced the old tired battery with an Optima....what a huge difference when cranking.
Cleaned up the spark plugs, checked and re-torqued the head and mounted the NH after checking the float level and replacing the bowl gasket.
Pulled and cleaned the trans oil screen and magnet, and topping off the oil level.
Posted: Thu Mar 17, 2022 7:43 pm
by CudaMan
I rolled up and put away my side curtains for the summer. In a month or so I'll remove the hot air pipe and install my air filter for the summer. :)
Posted: Thu Mar 17, 2022 9:06 pm
by Bob McDaniel
Second time out this year. Ice cream run.
Posted: Thu Mar 17, 2022 9:08 pm
by TWrenn
Drove it for the first time this year! Sorry, no pics this time! :lol:
Posted: Fri Mar 18, 2022 6:55 am
by Dallas Landers
Our icecream shops are not open yet Bob. Its going to rain alot this weekend so next week the T's can hit the road with no salt. Tim your slipping!😁
Posted: Fri Mar 18, 2022 9:10 am
by Ralph F
My wife and I are visiting family in Dayton this weekend and we had yesterday free so we took a trip over to the Model T Ford Museum. What wonderful place, I donated a set of transmission reamer for display or use in the work shop. I meet and a nice conversation with Rachel Executive Director what they are plans are going forward.
Posted: Fri Mar 18, 2022 3:20 pm
by Tbird
I cleaned up a new brass radiator that was in storage for a long time from someone else’s project. I unsoldered the wrong repo radiator tag and put on a authentic repo tag made by RV Anderson and soldered on the correct radiator gas crossover tube.
Posted: Fri Mar 18, 2022 6:51 pm
by J and M Machine
rebuilding a 1913 ,1915 and a 1925. Model T Hobby is alive and well around us.
Posted: Fri Mar 18, 2022 7:41 pm
by Sean Butler
Boy John, that block looks pretty pretty. Baked and peened?
Posted: Sat Mar 19, 2022 3:11 pm
by Chuck Regan
Model T’s representing at Conejo Valley Cars & Coffee this morning!
Posted: Sat Mar 19, 2022 5:03 pm
by Mark Nunn
I reinstalled the windshields on my Runabout. A local shop cut and installed safety glass. My old glass was plate! That was my final must-do safety project. Now we can toodle without fear.
Posted: Sun Mar 20, 2022 1:02 am
by Mikerobison
Model T Speedster Rebuild - Ruckstell Part 2
https://youtu.be/iItcDck-0XY
Uploaded a new video to the Speedster rebuild project. The Ruckstell assembly rebuild has begun! Thanks for watching!
Posted: Sun Mar 20, 2022 8:31 pm
by GBaker
My first post since I sold my 15 Touring 6 years ago.
In March I found a 26 Touring, Bought it, couldn’t get it into neutral, pulled the engine and transmission out, found seized jackrabbit clutch, bought a bunch of parts including high compression pistons and new stipe 290 cam, did a little body work, started on seat upholstery.
By the way, does anyone know where to find front wheel bearings these days??
Posted: Sun Mar 20, 2022 10:15 pm
by speedytinc
Were the outer disks stuck in wear notches in the drum? What was the hang up?
Posted: Sun Mar 20, 2022 10:39 pm
by GBaker
The lining material was stuck to the steel plates
Posted: Mon Mar 21, 2022 1:24 pm
by DHort
Grant
Rockauto is your best choice for bearings and seals. They had inners and one of the outers the last time I checked. The other outer has been back ordered for some time. There are a few guys here who might have some used ones. Ask in classified.
Posted: Mon Mar 21, 2022 6:30 pm
by Flivver
Overhaul the steering column.
Posted: Wed Mar 23, 2022 12:50 am
by jiminbartow
Getting my 1926 coupe running in preparation to sell it. Needs to run to take potential buyers for a ride and to teach them how to drive a T:
1. Restored my Hercules Split rim spreader: Using muriatic acid, removed all rust, dirt and old grease and painted original red color.
2. Using restored split rim spreader, I removed all of the old 52 year old 21” Universal tires tubes and flaps from the split rims.
3. Using Muriatic Acid, I removed all rust from the split rims down to white metal, then repaired the latches and painted silver.
4. Using split rim spreader, I mounted new 21” Goodyear Balloon tires, tubes and flaps. Lubricated with baby powder.
5. Aired up all the mounted tires to 32 lbs.
6. Touched up scratches on rims with Sherwin Williams Silver Brite paint
7. Cleaned newly mounted tires and wiped down with brake fluid to preserve the rubber.
8. Mounted all the tires on the car.
9. Cleaned and re-gapped Champion x Spark plugs to .025.
10. Drained old gasoline from cowl tank (smelled and looked like it was still good).
11. Cleaned fuel filter/valve (screen filter was clean. No debris whatsoever).
12. Added 5 gallons of fresh non-ethanol gasoline.
13. Drained and flushed engine of 3.75 qts. of old oil.
14. Took apart and cleaned oil sight gauge.
15. Poured in 3.75 quarts of Valvoline 5w-40 detergent oil.
16. Flushed radiator of old 50/50 mixture of antifreeze
17. Added 50/50 mixture of Zerex IAT (Inorganic Acid Technology) Antifreeze to the radiator.
18. Rebuilt and lubricated instrument panel switch assembly.
19. Reupholstering the behind the seat storage shelf. Old upholstery of shelf damaged by moths.
20. Using Blaster, freed up crank frozen handle grip so the hand grip turns n the crank.
21. Primed and painted hand grip gloss black.
22. Wash, polish and wax exterior of body. Polished nickel brightwork.
23. Removed air filter and installed hot air pipe
24. Removed New Day Timer and installed new old style roller type timer. Lubricated with mixture of Vaseline and 3 in One oil.
25. Filled fan reservoir with 5w-40 oil.
26. Removed and, using the vice and small sledge hammer, bent the Brake pedal backward so it is not so close to the floor when pressed.
27. Adjusted bands a little closer.
28. Lubricated speedometer cable.
29. Front crossmember clamp was loose. Tightened nuts.
30. Bought a new 6V battery from Auto Zone. Have it connected to a trickle charger.
31. Will try to start it in the next week or so. Looking forward to the attempt.
Been non-stop busy. Brought back lots of memories. May have second thoughts about selling…. Jim Patrick
Posted: Wed Mar 23, 2022 1:29 am
by Reno Speedster
Making progress on the suspension for my 26 Speedster. Cut down and welded the prop shaft to fit my lowering brackets and the Muncie transmission. I am now working on modified rear radius rods to fit my lowering brackets and to drop them down slightly. I have also started in on the front lowering brackets. I am a nut and am cutting/milling them out of a block of 1018 steel. The hope is to get a rolling chassis by spring so I can take it to the DMV to get the bonded title going.
I also am working with the shop to get my Rajo B head rebuilt and ready to go on.
On top of that, I am making arrangements to get the 22 pickup shipped up. Busy month and more to come.
Posted: Sun Mar 27, 2022 4:16 pm
by Dallas Landers
After installing the Twin Hasslers , I needed to take a drive and see how it drives and rides. Both were fine. About 25 degrees today and windy and if you look close , you can see snow flakes in the photo. My wife rolled her eyes when I asked if she wanted to go for a ride. Dressed for success, I pulled the upper board from floor boards and it was pretty nice.
Posted: Sun Mar 27, 2022 4:57 pm
by SteveD
Purchased it!
Posted: Sun Mar 27, 2022 6:22 pm
by DHort
Bought a new battery
Posted: Sun Mar 27, 2022 8:17 pm
by JohnM
Like Dallas, I went for a drive in spite of the chilly temperatures. The new gypsy curtains work well to break the wind from the front seat passengers. A digital tech marketing firm did a great job of repurposing this old service station.
Posted: Sun Mar 27, 2022 8:49 pm
by MichaelPawelek
83F here today on the Texas Gulf Coast so just took the ‘25 Coupe out around the neighborhood. Was stopped twice and asked to take pictures with the T. Did a bit of educating two under 10 year old boys about Model T’s.
P.S.-Finally decided to take that huge monstrosity off the radiator and replace with something much smaller! :)
Posted: Wed Mar 30, 2022 9:41 pm
by mbowen
Bonnie’s front axle is DONE! The last thing today was setting the toe-in, and reinstalling and cotter pinning the two nuts that had to be loosened or removed to make that happen.
Before she can be driven I need to install the refurbished cylinder head, new fuel line, and fuel shutoff valve at the carburetor. I also have a hand crank cleaned up, painted and ready to install (the car came to me without one).
Posted: Thu Mar 31, 2022 12:06 pm
by JBog
Drove my car to a distillery in a nearby town. About 90 miles round trip. The whole distillery came out to see the car, we had a number of honking cars, even a passing train honked at us!
https://www.youtube.com/watch?v=uNEqPnM2W0o
Posted: Thu Mar 31, 2022 12:17 pm
by Henry K. Lee
Had some serious other priorities...., Grand God Children needing to be spoiled by guess who! Hey.., they live in England and we see them every two years! 10 day turn around!
Detroit Parking!
Tin-A-See Restoration!
Hank
Posted: Thu Mar 31, 2022 1:51 pm
by Dallas Landers
Its nice you made it a 3 seater Hank. Even comes with saftey belts I see. Better than new I would say.
P.S. I am adaptable!
Posted: Thu Mar 31, 2022 2:36 pm
by Henry K. Lee
And you did not even see the airbag Dallas! I wrap them in bubble wrap!
Posted: Thu Mar 31, 2022 4:23 pm
by DHort
Good thing you didnt park it Chicago style. Wheels are always a plus.
by DHort
