1914 Ford Model T Roadster
Posted: Sat Mar 05, 2022 8:48 pm
by Craig E. Luton
Does the turtle deck on a 14 Ford roadster have a sheet metal panel fit inside the turtle deck that coves the opening between the turtle deck and body?
Thank you, Craig
Re: 1914 Ford Model T Roadster
Posted: Sat Mar 05, 2022 10:06 pm
by Wayne Sheldon
I know the 1915 does. I believe the 1914 does as well.
Posted: Sat Mar 05, 2022 11:19 pm
by Craig E. Luton
Thank you, Craig
Posted: Sun Mar 06, 2022 8:23 am
by George House
Yes. They do and my ‘14 runabout does
Posted: Sun Mar 06, 2022 8:33 am
by John kuehn
14 thru mid 22 Roadsters had the sheet metal back in the turtle decks. The change came in early 23 models. Somebody on the forum probably knows for sure.
Posted: Sun Mar 06, 2022 10:29 am
by sweet23
Here are some photos of an early trunk deck I have. hope they help. Darryl
Posted: Sun Mar 06, 2022 10:43 am
by Original Smith
My '13 runabout has a sheet metal panel that starts at the tack strip on the back of the body and goes all the way to the rear sill. All one piece.
Posted: Sun Mar 06, 2022 11:50 am
by Craig E. Luton
Thank you everybody, you all have been a big help.
Craig
Posted: Sun Mar 06, 2022 12:00 pm
by Rich Eagle
Darryl, thanks so much for posting those photos. Many turtles are found with all that removed making it hard to know what was there.
Posted: Sun Mar 06, 2022 6:29 pm
by Wayne Sheldon
The originals were spot welded into place at the top and sides. Nailed of course on the bottom. I tack-brazed mine I made into place since I don't have a spot welder.
Turtle decks as with bodies were produced by several companies. They varied somewhat in details and materials from one manufacturer to another. I can see some variations between the one Darryl B posted photos of and mine, also one I borrowed from a good friend to copy that front panel from to replace my missing panel.
Also, a lot of these turtle deck/trunks had a wooden floor as shown in the photos. A few originals I have seen did not have that floor, nor any sign that it ever did, just the wooden framework around the outer sides and front. Bolted down, the body's rear deck is the only floor in the trunk.
