26 t front body to frame mount missing
Posted: Fri Mar 11, 2022 1:43 pm
by Dave Foley
front body to frame mounts were removed does anyone have replacements or a drawing to fabricate from? Thanks for your help
Re: 26 t front body to frame mount missing
Posted: Fri Mar 11, 2022 2:07 pm
Haven't a drawing or part replacement, but here is a pic of what that front frame mount looks like.
Posted: Fri Mar 11, 2022 5:03 pm
Do you have one on the other side? You might need to make one mirror image of the other. Those are usually ok and attached to the body, so I don't think the vendors have them, but should not be hard to make for someone with the right tools, or possibly remove them from an existing body which is too bad to restore.
Posted: Fri Mar 11, 2022 8:01 pm
by tdump
I salvaged 1 a few weeks ago when I was making 1 cowl out of parts from about 5. I will go see if I can lay my hands on it and if I can ,just help me out with the shipping.
I found it,it has a cut from the grinder on the side,can be welded up,still very rusty with dirt and the rusty sheet metal still riveted to it.
Posted: Sat Mar 12, 2022 9:09 am
by Dave Foley
I do need both sides, the previous owner was going to hot rod it and had removed them, thanks for the picture helps to see what im looking for
Posted: Sat Mar 12, 2022 3:57 pm
by Will Brown
Here is a much-enlarged shot of the brackets in question. The photos are hampered by a metal channel used to support the body when it was on the rotisserie. The metal channel is marked by the red arrow.
Posted: Sun Mar 13, 2022 1:52 pm
??????? Looks like electrical metal channel ??? It comes in many sizes
Posted: Sun Mar 13, 2022 1:56 pm
reread Will's post, Frank
Posted: Sun Mar 13, 2022 2:22 pm
Dave Foley wrote: ↑Fri Mar 11, 2022 1:43 pm
Are these what you need - recently listed on eBay so Hurry - seller is a good guy will take a reasonable offer - From Canada
https://www.ebay.com/itm/284699164209?h ... 8A&vxp=mtr
Posted: Sun Mar 13, 2022 4:20 pm
and there they are, on a silver platter
