Driveshaft bushing
Posted: Thu Mar 17, 2022 6:30 pm
by CazeaultsModelTs
I cannot get grease through the driveshaft bushing, is it a hole straight through the bushing or is it a channel that delivers it to multiple locations?
Re: Driveshaft bushing
Posted: Thu Mar 17, 2022 6:39 pm
by RajoRacer
Depends if it was installed correctly & either an original or a correctly made repro but yes, there is a grease galley.
Posted: Thu Mar 17, 2022 7:25 pm
by TRDxB2
I believe the process : The bushing is to be inserted with the oil groves aligned with the oil hole in the torque tube then the hole is drilled an then the busing is reamed & faced.
Posted: Thu Mar 17, 2022 8:31 pm
by CazeaultsModelTs
It appears that once again this guy installed something incorrectly, the bushing is 180degrees off.
Posted: Thu Mar 17, 2022 8:41 pm
by Dropacent
It could have spun, too. The repro’s are sometimes a loose fit and need to be glued in.
Posted: Thu Mar 17, 2022 9:18 pm
by Oldav8tor
If you decide to remove it be careful. More than one guy has sheared off rivets trying to drive it from the far end of the tube. You want to use a puller designed for the purpose.
Posted: Thu Mar 17, 2022 9:36 pm
by RajoRacer
I just removed & replaced the same bushing that was installed incorrectly - they drilled the hole but it was opposite the grease slot.
Posted: Fri Mar 18, 2022 2:11 pm
by CazeaultsModelTs
It could have spun but everything this guy installed has been incorrect so far
Posted: Fri Mar 18, 2022 6:14 pm
by Sean Butler
You have to appreciate consistency... :(
Posted: Fri Mar 18, 2022 6:46 pm
by Les Schubert
Considering how much oil most T’s leak by the ball cap I wouldn’t think it is a big deal. I haven’t greased that bushing in 45 years.
Posted: Fri Mar 18, 2022 9:17 pm
by TRDxB2
I'm with you. But your suppose to put grease in the Ball Cap to lube the u-joint and oil to lube the drive shaft bushing. I think that theory was that the oil would dilute the grease seeping into the busing providing the intended consistency.
