Wood Wheel Hub Covers
Posted: Fri Mar 25, 2022 12:35 pm
by DontKnowMuch
I am looking for information on these "Wheel Hub Covers". They are aluminum and I believe they will fit over the later wood wheel hubs. I have done a few searches but my search criteria were too general and did not produce any results for these. I need to know how they were held in place.
Do you know who made these? Do you have any like these?
Any help will be appreciated.
Dennis
Re: Wood Wheel Hub Covers
Posted: Fri Mar 25, 2022 12:45 pm
by speedytinc
There is a small lip on the edge that the hub cap touches when screwed on all the way. Hub cap holds them in place. I do have similar units & matching aluminum headlight rims with the red stripe.
Posted: Fri Mar 25, 2022 1:30 pm
by DontKnowMuch
Thanks for the response. I would love to see pictures of what you have.
Do you have any idea who sold these originally?
thanks
Dennis
Posted: Fri Mar 25, 2022 2:20 pm
by speedytinc
DontKnowMuch wrote: ↑Fri Mar 25, 2022 1:30 pm
thanks
Dennis
I have seen them listed in some accessory catalogs. I dont recall where or the mfg name. Ill look thru my literature.
Posted: Fri Mar 25, 2022 2:56 pm
by TRDxB2
thanks
Dennis
Found this
http://www.mtfca.com/discus/messages/82 ... 1532871340
Another odd ad
Posted: Fri Mar 25, 2022 3:42 pm
by Franko
James, it appears that you have 4 front covers. I reproduced these out of brass a few years ago. They are held on by the hub cap. Tim franko
Posted: Fri Mar 25, 2022 5:55 pm
by DanTreace
Most all of those accessory hub covers came with special hub caps to secure, some fit ok with std. Ford hub caps.
Try by test fit. Covers were made for other cars like Chevy.
On this hub cover, found by itself, had to modify the opening of the hub cover, and then an accessory cap pinched it tight so no rattles.
Another set
And another;
Posted: Fri Mar 25, 2022 9:58 pm
by ModelTWoods
I have two sets of the covers, pictured above with the red trim. One set is used and doesn't have the hub caps. The other set is NOS and has the correct hub caps and has only been out of the original box for inspection and photos. If I don't use them, someday, you'll see them in the Classifieds 'for sale', but that is a ways down the road. Next time I dig them out, I'll take another photo and post picture of box and instructions.
