Best upgrade yet, better everything
Posted: Fri Mar 25, 2022 7:02 pm
by BobP
Better than a high compression head, better than a warford, better than almost anything. Apex carburetor throttle, (pneumatic butterfly) 25%-50% more miles to gallon, easier starting, more power on hills, more power on heavy pulls, less carbon in your motor, reduced oil consumption, reduced repair bills, more pep in a sprint, quicker getaway. Fits kingston and Holly carbs with 1 inch carb. Why don't they still make them? It would be a very inexpensive option.
Re: Best upgrade yet, better everything
Posted: Fri Mar 25, 2022 7:08 pm
If you fit a longer shaft to accommodate a second device on the other end, would that give 50-100% savings?
Posted: Fri Mar 25, 2022 9:36 pm
These incredible miracle devices would be available to all at no additional cost except for the fact that agents of Big Oil bought them all up and dumped them into the sea in a secret location and then they locked up the prominent European Scientist who discovered the secret molecular realignment principles that cause ordinary low-test gas to release the kind of blazing power previously available only to daring aircraft test pilots using special Army Air Corps fuel!
Posted: Fri Mar 25, 2022 9:43 pm
Beat the pump pirates! Put new, thermoplastic translucent clothespins on your fuel line!!! Power robbing motor sludge and gritty carbon deposts are blasted away as you enjoy faster accelleration, higher top speeds, and 35 to 50% improvement in gas mileage using any old cheap gas! Supplies are limited, so ORDER NOW before the Big Oil Pump Pirates force us to take down this special commercial message!
Posted: Sat Mar 26, 2022 9:40 am
by MWalker
If you believe all that Apex spiel, I can make you a heckuva deal on some oceanfront property in Arkansas. :D
Posted: Sat Mar 26, 2022 9:52 am
Caution! Adding three or more of the devices can cause your gas tank to overflow on long trips!
Posted: Sat Mar 26, 2022 10:18 am
by otrcman
The bad news is that if all cars used these fantastic gas saving devices, gas stations would have to become dumping stations. Every few hundred miles you would have to stop to drain out all the excess fuel. The dumping stations would charge by the gallon to drain your tank. To meet EPA disposal standards, the stations would charge $5 per gallon to haul it away.
Dick
Posted: Sat Mar 26, 2022 10:57 am
by dobro1956
M Walkers post is a scam. I own all the ocean front property in Arkansas. Contact me for the best rates ....,
Posted: Sat Mar 26, 2022 5:11 pm
by MichaelPawelek
I personally liked the throttle plate that would lock closed so no one could steal your Model T!
Posted: Sat Mar 26, 2022 5:43 pm
by Art M
I had one on my car and found it isn't compatible with MMO
Art Mirtes
Posted: Sun Mar 27, 2022 2:40 pm
by OilyBill
Harumph!! You kids today!
I put THREE of those on, and now I don't even fill up my gas tank! It stays full all the time.
Also, this thing STOPS all the rattles, my transmission shifts much better, and I have a totally free neutral! Additionally, when I use my lights, the battery NEVER goes down, even though I have gas lights!
On top of all that, my front steering shimmy is gone, my rear axle whine is now just a hum, my seats are much more comfy, and my windshield NEVER gets dirty!
AND, I noticed that all my brass has become self-polishing! Why, I don't lift a finger before a tour! I just go inside and watch Gilligan's Island re-runs, and when I come back out, the car is gleaming!
My teeth are whiter, too!
This is the best $2 I EVER SPENT!
Posted: Sun Mar 27, 2022 3:14 pm
This scientifically-correct device will also house-train any dog of any age... even a wild dingo! Absolutelyy ends "accidents" and eliminates "doggy odor"! Removes mothers-in-law from guest rooms and elimates those pesky wallpaper stains!
Posted: Mon Mar 28, 2022 7:37 am
by ironhorse
Yes but will it evict slimy non-paying tenants from your rental property?
Posted: Mon Mar 28, 2022 8:28 am
Evicting squatters is illegal!
Posted: Tue Mar 29, 2022 11:59 am
by jiminbartow
I was going to post that I have had one of these on my T for 50 years and except for the fact it is adjustable and positions the throttle connection 1/4” higher and a little longer, it makes no difference whatsoever. After I read several responses I realized it was not a serious thread, endorsing a miracle accessory that does nothing that it claims. Only what the original one does. I guess the mechanical equivalent of snake oil patent medicine claims. Jim Patrick
Posted: Thu Mar 31, 2022 9:51 am
by jab35
Hopefully the OP makes it into the Accessory of the Day archives on this forum. Love that and all the serious technical discussion that followed!
Posted: Fri Apr 01, 2022 8:48 pm
by tdump
Reminds me of all the "You can save up to 40% by switching to our car insurance" commercials.
It is made to appear that I could get insurance with company A, then later switch to company B and then later to C and before you know I would be getting PAID to have car insurance! :lol:
Posted: Fri Apr 01, 2022 9:19 pm
I wonder how it works with a water injector? You should use STP in the crankcase and Marvel Mystery oil in the gas and a water injector on the intake manifold. With those three and the special throttle, you could become a source of high price gas for sale to others! :lol:
Posted: Fri Apr 01, 2022 9:34 pm
STP is good stuff, but Bardahl is great on mashed potatoes.
Posted: Sat Apr 02, 2022 12:25 pm
by John Codman
I remember the "mini supercharger" That had rotating blades and bolted between the carburetor and the intake manifold. It gave you much more power and better gas mileage!
