Modern seal for front of camshaft
Topic author - Posts: 13
- First Name: Colin
- Last Name: Watt
- * REQUIRED* Type and Year of Model Ts owned: 1915 Tourer
I have the full gasket set for my 1918 engine, which I am reassembling. Whilst it has a modern seal for the front of the crankshaft it has the old felt seals for the front of the camshaft. Is it possible to obtain a modern seal, in the UK, for this? The UK Register does not hold them. Regards, Colin.
Re: Modern seal for front of camshaft
Colin
my standard advice is 'call Langs', but that's an expensive proposition for you, huh? In that case, see this: http://www.mtfca.com/discus/messages/70 ... 1504957707
or measure OD/ID/depth, and order an appropriate SKF seal from their on-line catalogue.
NH Full Flow Float Valves
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
Here's the # for a CR seal:
12458
You should be able to order directly from a parts house over there. This one is very thin with a metal frame so it can be modified easily to glue onto the outside on the front of your engine. Some guys install this into the inside but this can cause issues when you want to remove the timing cover later.
Good Luck
12458
Good Luck
1912 Torpedo Roadster
- Last Name: Andreasen
- * REQUIRED* Type and Year of Model Ts owned: 0...building from parts
I used a modern camshaft seal ordered from Snyder's. It fit in the recess somewhat loosely, but this is normal as some castings are different from year to year. The only problem I ran into was how to get the seal "lips" over the sharp edge of the cam where the threads end. I solved that by turning an aluminum "bushing" whose outer diameter was a couple thousandths larger than the cam. The center was drilled so as to slide over the threaded portion, and the end slightly tapered for the seal to slide over. I oiled the "bushing" and pushed the seal on it, then slid the bushing over the cam, then pushed the seal in place. Worked like a charm. JBWeld was then worked around the seal edge. If the seal needs replacement in the future, a propane torch will heat the JBWeld until it releases.
- First Name: Gene
George, I believe the poster was referring to a modern crankshaft seal. Next time try Ultra Black sealant to pot your seals in instead of JB weld. It seals much better and is flexible which is good during the heating and cooling of the engine. Much easier to get apart as well.. Many guys use a wrap of black electrical tape to protect the seal during install also.
YMMV
YMMV
- Last Name: Pringle
Hi Colin
You can get that seal from the T Service 01869 351006 or Tuckett Bros 01296 670500
Cheers
Cheers
- First Name: Gene
Sorry George, I read the original post again and put my glasses on... Cam shaft seal is SKF9853 over the counter at your supply house.
That's okay Gene..........I read it again too just to make sure I didn't give the poor guy the wrong dope!
