FABRICATING A SPARE TIRE CARRIER FOR TOURING
Posted: Mon Mar 28, 2022 11:24 am
by Tom Donnelly
Attached is a condensed photo summary of how I fabricated a rear tire carrier for my '21 T that has 30-inch split rims. It began with a salvage bracket I purchased as one assembly from Mark at Model T Haven, before he closed shop. These assemblies are also available on eBay. To cut down on weight, the frame might also be fabricated with aluminum.
Fabrication of Spare Tire Carrier.pdf
(1.16 MiB) Downloaded 192 times
Re: FABRICATING A SPARE TIRE CARRIER FOR TOURING
Posted: Mon Mar 28, 2022 12:13 pm
by MichaelPawelek
I did the same a few years back by taking the mounting end of one carrier, cutting it off, and welding it to the 21” split rim carrier. My ‘19 Touring came with 21” split rims and I needed a good way to carry a spare….:)
Posted: Mon Mar 28, 2022 7:04 pm
Tom, nicely done. Are your rims ex Chev rims? I have those on my 24 tourer, just because I found 4 straight sided tyres the correct size for the car,4.40 x 23"
Posted: Tue Mar 29, 2022 12:41 pm
by Tom Donnelly
Thanks for compliment Allan! I think you're right that they are Chevy rims. Car and most of its parts over the last three years have come from Mark Freimiller's 'Model T Haven' which he closed and auctioned everything last November (see link below). Really going to miss his wisdom and used parts inventory! With regard to the project, goal was aesthetics, as I wanted the tire positioned higher and yet not to interfere with the top in down position. It appeared that most of the traditional spare mounts and attachments I found ended up with the tire positioned lower, which makes sense for function.
https://www.iolaregister.com/news/model ... n-era-ends
