Fitting pedal trim
Posted: Sat Apr 09, 2022 3:29 pm
by Ralph F
I have been working on getting the pedal trim to fit properly. Before I do something that I will regret, I thought I ask for some help
Fitz
Re: Fitting pedal trim
Posted: Sat Apr 09, 2022 8:50 pm
by Oldav8tor
Leave a little gap so the ends don't touch and rattle....found that out the hard way.
Posted: Sat Apr 09, 2022 9:19 pm
by Scott_Conger
Ralph
you are about to discover that your pedals are likely bent every way but where you want them to be. Note that the pedal spacing on the trim is not equal! Study the pedals to see which direction left/right that the pedal supports move each pedal through its travel and align the pedals to the slots such that full travel can be had without binding along the side of the trim.
It may take more time and tweeking than you expect.
have fun! (I consider it an annoying job, myself, but patience and care will pay off)
Posted: Sun Apr 10, 2022 8:50 am
by John kuehn
Here’s something that will help. Make sure your pedals aren’t bent like Scott C. says.
Then get you some stiff cardboard to make some templates for the floor boards. You can get the spacing pretty close by doing this.
You can use as many pieces of cardboard as you want to get it right! Then transpose them to the wood floorboards. Hope this help!
Posted: Sun Apr 10, 2022 10:35 pm
by Dennis_Brown
Good idea using cardboard. A lot cheaper to make mistakes on than plywood.
Posted: Mon Apr 11, 2022 11:39 am
by Original Smith
You didn't say the year of your car! The holes in your trim pieces are for semi-tubular rivets used to hold the draft deflector on the later model cars, and are available from Langs.
Posted: Mon Apr 11, 2022 12:20 pm
by Ralph F
Thanks for the information the pedal trim is for a 22 model t roadster
Fitz
