Small rear axle brake drums
Posted: Mon Apr 11, 2022 6:33 pm
by dang.1922
Is anyone making the small rear drums, the vendors tell me that they are discontinued now. Thank You—-Dan
Re: Small rear axle brake drums
Posted: Mon Apr 11, 2022 10:28 pm
by Dan Hatch
What is wrong with a good used drum?
Posted: Mon Apr 11, 2022 10:49 pm
I'm with Dan - I have a 5 gallon bucket of them !
Posted: Tue Apr 12, 2022 12:58 am
Probably discontinued due to low demand. That's one of the original parts so plentiful they're hard to give away.
Posted: Tue Apr 12, 2022 6:37 am
by dang.1922
One of my drums is cracked and I have never picked up any used ones to have around. I thought I would try the venders first before looking for a used one. Dan
Posted: Tue Apr 12, 2022 9:46 am
by CudaMan
I wish cast iron drums were available for Model Ts, like they are for Model As. I suspect they would provide a higher friction coefficient for external band brakes.
Posted: Tue Apr 12, 2022 12:55 pm
by walber
Nash Metropolitan drums are the right size and with a bit of work on a lathe on the inner face and re drilling the bolt holes they work fine. They are also reproduced and not terribly expensive at $40 or $45 each).
Posted: Wed Apr 13, 2022 6:16 am
by dang.1922
Thank You for the information on the drums, a friend of mine had an extra one so I am set to go. ---Dan
