Hudson Hogshead for Fords
Posted: Fri Apr 15, 2022 2:33 pm
by Tadpole
Found this interesting photo of an accessory made by Hudson Motor Specialties of Philadelphia, sure makes lining replacement look easy.
(Photo taken from the Library of Philly archives)
Re: Hudson Hogshead for Fords
Posted: Fri Apr 15, 2022 2:51 pm
by Dan Hatch
I have heard that hard to stop from leaking too. Dan
Posted: Fri Apr 15, 2022 6:01 pm
by Wayne Sheldon
Wasn't that marketed as the "Hudco"?
I have seen a few of them over the years.
Posted: Fri Apr 15, 2022 6:21 pm
Here is a link about it and more pictures http://www.mtfca.com/discus/messages/80257/116389.html
Posted: Fri Apr 15, 2022 7:22 pm
Has any one seen one of there covers actually on T over the years? Kinda of neat if they would work. With the improvements in sealant’s over the years maybe leaking wouldn’t be a big issue.
Posted: Fri Apr 15, 2022 7:43 pm
I wonder what the purpose was for the large plug next to the magneto pickup.
Posted: Fri Apr 15, 2022 8:11 pm
by Tim Rogers
You can service the back of the horn while you're at it...
Posted: Fri Apr 15, 2022 8:17 pm
The large plug was the access port for cleaning out the oil funnel. Hudson also made a nice set of c.c. repair arms ! And yes, they were called Hudco Covers.
I have one on my parts shelf - figured next time I pull the engine on the Centerdoor I'll install it - ever attempted a band change in a Centerdoor ? Not for the faint of heart !
Posted: Fri Apr 15, 2022 8:56 pm
I would think when these were made you would buy the cover and add your existing pedals and parts to the Hudson cover. But that’s a guess. I haven’t seen one over the years but I wasent looking for one either. Probably don’t show up to often if at all.
Posted: Fri Apr 15, 2022 9:15 pm
That makes good sense Steve. Interestingly, the fitted on in the initial post does not have it. It is an early starter car with the squared off tin can bendix cover, so perhaps the good idea came later.
Posted: Sat Apr 16, 2022 7:52 pm
by Farmer J
Steve Ellis donated one to the MTFCA Museum this spring. Looked like it would make changing bands a snap but sealing it up would be impossible.
Posted: Sat Apr 16, 2022 8:11 pm
by SurfCityGene
Farmer J, You must not have ever used Ultra Black? That'd be the perfect sealant, tough and flexible with super adhesion. I've toyed with the idea of converting one of my alum HH's since I've found them fairly easy to weld on? There is even less room for changing the bands on those.
Posted: Sat Apr 16, 2022 10:30 pm
by Jack Putnam, in Ohio
I had one, put it on a TT for looks as I never had to change the kevlar bands. Sealing was not a problem as I used the felt from the band changing kit that I coated with silicone. Never leaked. Before modern sealants I'm sure it was a problem.
