how to remove & replace hub bearing cup
Posted: Wed Apr 20, 2022 12:31 pm
by andy2794
Are there some easy to follow instructions on how to remove & replace hub bearing cup?
Re: how to remove & replace hub bearing cup
Posted: Wed Apr 20, 2022 3:49 pm
by Jerry VanOoteghem
Slip a long punch into the back end of the hub and position it in one of the two notches, (see arrow). The notches allow access to the backside of the cup. Tap the cup out by hitting it on its backside. Alternate between the two notches to drive it out straight. If you get it cocked you'll stretch the hub nose and ruin it.
Same process for the large cup removal.
- Capture.JPG (11.73 KiB) Viewed 1259 times
Posted: Wed Apr 20, 2022 4:26 pm
by George House
OR......if you have an arc welder; strike about an inch of weld on the cup across from each other. It’ll probably fall out after that shrinks it
Posted: Thu Apr 21, 2022 8:34 am
by andy2794
thank you for the advise
