Looking for front axle repair service or access to a Stevens front axle repair tool in NJ/NY/PA/CT area
Posted: Tue Apr 26, 2022 12:46 pm
by ahovey
Hi, I am in the process of rebuilding my front axle and I wanted to see if anyone offered a repair service around NJ or had a Stevens front axle repair tool that I could potentially get access to.
Appreciate any help.
Austin
(201) 306-7112
Hoboken, NJ
Re: Looking for front axle repair service or access to a Stevens front axle repair tool in NJ/NY/PA/CT area
Posted: Wed Apr 27, 2022 5:33 pm
by ahovey
back to the top
Posted: Wed Apr 27, 2022 7:46 pm
by SteveD
It's a brave man that drives a T around Hoboken
Posted: Wed Apr 27, 2022 8:02 pm
by Moxie26
Austin.. are you interested in just replacing the bushings or is there a twist in the axle that needs straightening?.... If you have access to a Model T service manual that will help you. If there is a twist in the axle, large pipe wrench with an extension on the handle can be used to help straighten the axle outboard of the spring purch. If there's any damage to the center section of the axle I would just overlook and concentrate on the ends of the axle to true up measurements.
Posted: Wed Apr 27, 2022 9:28 pm
by ahovey
Steve - not brave enough with a T that isn’t in alignment anyway.
Robert - I primarily need to use the tool to replace the upper bushings and the threaded inserts. I would do it on a mill, but I don’t have the proper taper reamer and fear there is a risk of the two inserts not being concentric.
I have not received the axle yet, but was told it has a slight bend in the center. I have turned a few steel shafts that I will use to check the alignment from the spindle ends and the perches similar to the method in the service manual. I will use a strong hydraulic press to get that straightened out.
Posted: Wed Apr 27, 2022 10:02 pm
by Moxie26
For what year model T will this axle be used?.. looking at the axle horizontally the top edge will appear to have a dip in the center, and this is normal.
Posted: Wed Apr 27, 2022 10:35 pm
by ahovey
It’s an early, no ford script, T-202 axle going on an ‘11. The bend in the axle I believe makes it bow outwards slightly per the seller.
Posted: Thu Apr 28, 2022 2:49 pm
by Moxie26
Check for play in the kingpin and bushings. Replacing with new bushings and King pins may solve your problem
Posted: Thu Apr 28, 2022 3:49 pm
by ahovey
I have brand new .502” kingpins and new bushings in the spindles so I don’t expect play there. I was told the axle would need new threads on the bottom, so that’s what I need to use the tool for. The potential bend in the axle is another issue.
Posted: Tue May 03, 2022 3:17 pm
by ahovey
Back to the top, I will be at Luray.
Posted: Tue May 03, 2022 4:02 pm
by JTT3
Contact Dan Hatch, he’s going to Luray and may be able to help you.
